Whitedove
| Posted: June 13, 2006 2:52 pm | ||||||
Whitedove
I can't get any of the presets to work. What am I doing wrong?
Donna |
| Posted: June 13, 2006 2:53 pm | ||||||
Lucato
Hi Donna, pretty weird. Here is working fine. Have you verified if It isn't checked '[v] Show Original'. Have you tried to right click and use apply preset or click twice on the preset?
| Posted: June 13, 2006 4:04 pm | ||||||
Whitedove
Hi Lucato,
I verified that 'Show Original' is not checked and I tried to right click to use apply preset, clicked twice on it and I tried it with just the Apply button in the lower right. This is what I see in FF, but after I apply the preset, nothing happens to the original picture. Also, when I try the default preset, nothing shows up in the center of the frame in FF. ?? Donna ![]() |
| Posted: June 13, 2006 4:39 pm | ||||||
Whitedove
| Posted: June 13, 2006 5:05 pm | ||||||
Whitedove
Lucato
Ops, I'll need to review that or add a better description. Donna, I checked It out and here goes the results:
To apply the 'default' preset or the presets that has no sample image behing it, try to create a new layer and apply it on a new layer instead of applying on the layer of the image. About the 2nd presset (presets w/ the sample image), you cannot apply themt when the image is flatten (background). It needs to be applied as layer instead of background. Try this way and tell me what happened. |
| Posted: June 13, 2006 5:16 pm | ||||||
Whitedove
| Posted: June 13, 2006 6:05 pm | ||||||
Lucato
Well, It worked. Donna, I got to fix some part of It. I mean, the 'Default' and similars. The others I'll need a help as I've posted here. I'm sorry for the inconvenience, but we all are still learning. |
| Posted: June 13, 2006 6:22 pm | ||||||
Whitedove
Don't be sorry...JUST FIX IT!! (just kidding)
I love the filter, I don't mind making the clipping mask. Thank you, Donna |
| Posted: June 13, 2006 7:26 pm | ||||||
Whitedove
Cool effect, no?
| Posted: June 13, 2006 7:29 pm | ||||||
Lucato
Good one.
A little sanguinary, no? You scare me |
| Posted: June 14, 2006 3:30 am | ||||||
Whitedove
You think I'm scary?
Take a look at the rest of this artist's work... Frank Frazetta; The Master of Fantasy Art: http://frazettaartgallery.com/ff/index.html |
| Posted: June 14, 2006 6:53 am | ||||||
Andrew B.
This seems to only work correctly on square images. On a portrait, it makes a square frame, and below that it makes part of a square frame.
| Posted: February 23, 2012 5:37 pm | ||||||
Yep it does say that in the filters info....
This filter was created in FF1 which only had support for square images in some instances... Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: February 23, 2012 8:30 pm | ||||||
Beautiful frame and effect !
Could this be updated to use the NON square images ? How would you do that ? Lucato could do it but he is nor here very often so I do not think he will be able to do it and update this filter to FF 3.0. |
| Posted: February 24, 2012 12:45 am | ||||||
Yeah, I haven't figured out yet how to make non square filters work right either. Yet
| Posted: February 24, 2012 3:03 am | ||||||
52 unregistered users.
