Mesh 3D Vol 2 by pixel8ted
http://www.filterforge.com/filters/5033.html ![]() If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: January 25, 2008 10:04 am | ||
i like this. everything from stamped metal to a sort of barbed wire look.
ScaryKitty
Neato! I love pattern textures!
he Design Thickness slider creates the smallest design at setting 1. Unfortunately, the slider will not react to thicken the design until it's around 50+. I haven't worked out how to get around this. I wondered about this, so I had a look-see. It's something about the type of curve you use at the very beginning. I found that if I connected the "design thickness" slider to "percentage" as well as "fade to," and set the remapping values to min=5, max=50, I could get a pretty smooth transition from wire-thin to slab-thick. You can also connect "design thickness" to "fade from," but I found that setting the remap values wasn't as straight-forward as using "percentage." Of course, a lot is dependent on the shape size of shapes 1 and 2, but ya can't have everything, can ya? Kat
----------------------- "Listen, gotta dash, things happening. Well, four things. Well, four things and a lizard." -The Doctor |
| Posted: January 25, 2008 11:34 am | ||
pixel8ted
ScaryKitty,
...but ya can't have everything, can ya?
Thanks for the tip. Terri |
| Posted: January 25, 2008 12:38 pm | ||
Vivian C.
Good job. I like it.
| Posted: January 25, 2008 4:18 pm | ||
