The downward spiral by Sjeiti
http://www.filterforge.com/filters/5021.html
Cool one!
I'd remove the 'Center X/Y' functionality to keep it always centered though, plus I'd tighten the remapping on the 'Color repeat' as it doesn't randomize predictably with that large of a value range. smile:dgrin: smile:devil:
Mousewrites
Not life size.
See, I like that we can make it off-center.
Try randomizing the texture then... smile;)
I initally needed the xy offset, and a selection component, which is why it is filed wrongly in the 'Effect filters': I accidentally left an unused image component in there smile:blush:.
I think I'll make two versions of this one (effect and texture) and leave the offset out of the texture version.
I don't know about tightening the color repeat though, because the highest 'Color repeat' with a low 'Swirl' still looks good, and this is actually the effect I needed when I made the filter. I just got carried away a bit with the swirl eventually (the twist wasn't even in there at first).
Cool stuff, I liked the fade to brightness effect on this, made me wonder if you had used the HDRI lighting just for that. smile8) There were 2 little sub-groups of unconnected modules inside it though, cleanup isle. 3 smile:D
Cool!!! smile8) I really like the water ripple preset.... smile:)
nice update. glad you removed that overly bright center! some interesting variations in there, also.
ScaryKitty
This is as Normal as I get...
Filters: 40
This is so cool! I like that you can get some kind of Celtic triskelion effects. smile:D
And some of those wobblier variations (I'm thinking of variations 1 and 7) are worthy of a Fillmore poster. smile;)
Good job!
Kat
"Listen, gotta dash, things happening. Well, four things. Well, four things and a lizard." -The Doctor
Fianna
This filter made my day smile:)
James
James
Filters: 46
Cool filter, I can see this one being able to make some nice op-art for sure smile:)
