Old checkboard by Ipsissimus
http://www.filterforge.com/filters/4999.html
Nice filter.
The texture map is great, only the bump (and normal) are as clean as the day you bought the checkerboard. You should make it look a bit older, chip away at the corners a bit, maybe some cracks.
Ipsissimus
Filters: 10
Thanks for the advice. I've just changed it and resubmit it with a less regular surface and edges. I hope you'll like the modification. smile:D ...
19 unregistered users.
