Rawn (RawArt)
Texture Artist
Filters: 105
Soft Watercolours by ScaryKitty
http://www.filterforge.com/filters/5000.html
Rawn (RawArt)
Texture Artist
Filters: 105
Very nice effect
Nice work!!! I really like what you did with the edges..... smile8)
havent tried it out yet, but looks good on paper smile:)
Cool look to this one.. smile:)
ScaryKitty
This is as Normal as I get...
Filters: 40
Thanks, all! smile:D
I worked a very long time on this -- more time than it warranted, I expect. I really wanted to get a look that included colours not just bleeding outward, but actually mixing. I don't think I've really caught that yet, but I'm closer. ^_^;
Well, and after all this work, an update is coming soon: after playing with the filter with some other images, I didn't like how dark the colours kept coming out, so I went in there and fixed that. Now I'm working on a better outline routine for more complex images, especially those with lower contrast. I swear, using the lifesaver can be so misleading! smile:-p
NOTE TO SELF: Always use several images as guinea pigs!
Again, thanks for the encouragement, everybody. Kisses!
Kat
"Listen, gotta dash, things happening. Well, four things. Well, four things and a lizard." -The Doctor
hi kat,
check out some of northernshadow's filters for ideas. yours here reminded me of her 'chinese watercolor' and you might get some ideas from that one.
ScaryKitty
Filters: 40
Hey, Kraellin!
"Chinese Watercolor" is actually by MeKenzie. Is that the one you meant? Or did you mean another watercolour filter by northernshadow? I have northernshadow's "a watercolor painting" and did look at it a long while ago now. ^_^; MeKenzie's "Chinese Watercolor" is nifty, but not the look I was going for.
I bet you mean "a watercolor painting," now that I look at it again. I'll give its guts a look-see and see if any inspiration pops out. smile:D
Kat
you're right, sherri didnt do chinese watercolor. hmmm, now i dont know which one i meant.
ok, i had to go look at chinese. yes, this is the one i meant, so i had the author wrong. i've modded this one myself and used it. good filter and since i modded it a bit recently for a piece, that's the one i meant. it's got some good routines that you might borrow or idea from.
Looks very good -- probably the closest filter to actual watercolors I've seen to date. However, it has a significant problem -- speed. It's slow to adjust, and quick adjustments are a necessity for this filter, because its defaults don't look very well on photos with people and faces.
To improve the speed, I'd look at the topmost branch. I noticed that you apply a blur to a tone-curved and previously blurred sub-branch -- I think it's redundant, try to rearrange it.
ScaryKitty
Filters: 40
Thanks, Vladimir!
I was concerned about speed, too, but I at least wanted to to get the new version out, because I hadn't liked how the colour adjustments were working in the original, and the original outline routine, though it worked great for the lifesaver, didn't work very well for more complicated scenes.
I'm currently swamped with a work deadline, but I'll get to it as soon as I can.
Thanks again for the input! smile:D
Kat
