Glass Bricks by Carl
http://www.filterforge.com/filters/4995.html
cool, carl smile:) can you turn the background image off on this one?
Cheek.....cheek.....cheek.....Cheek of Earl smile:dgrin:
Very noice!!! Yeah, I would take the external image out of this one......and call it "Glazed Ceramic Tiles"..... smile;) smile:)
Excellent work!!! smile:) smile:) smile:)
i wouldnt take it out, i'd just make an option smile:)
Thanks for poping in
there is an alpha switch, but I was tempted to put one in that had a white colour B/g
boy you guys know how to confuse a person smile:D
There are a couple of glass brick filter in the library all pretty boring [ shameless bashing but true smile:D ] and I had this one in my pile so cleaned it up and here we are today smile:D
thanks for commenting smile;)
Don't listen to Craig.....listen to me!!! smile:dgrin: Remove the external image!!! smile:dgrin:
I don't think there are "Glazed Ceramic Tiles" ( smile:dgrin: ) like this in the library..... smile:|
Okay, we're going to need a third professional opinion on whether or not to loose the external image.....I don't think it goes with it at all.....and much more usable without it..... smile:-p smile;) smile:D
ronviers
lighter/generalist
Very nice Carl. I remember I used to see glass blocks everywhere, especially in office buildings, but now I hardly seem them at all. I seem to remember mostly green glass.
How about an opinion from the peanut section instead. smile:)
I would definitely leave the image in and refract it a tiny bit (.5 or so) using the blur coming off the inverted gradient as the height - just to help sell the glass. I also prefer a normal (with opacity control) rather than a darken blend mode to tie the image to the glass. And like that's not enough I also think the refection blur broke out (limited to about 65%) with a slider really helps. These are just thoughts, I like it just as it is. smile:)
@ronviers
here's a thought, and bear in mind that i havent actually looked at the guts on this one yet, so maybe you've already done this, but, what if you set the image component to the height of the results component? the current image looks to be blended INTO the glass a bit on some of those presets, so, if you moved the image to the height control and darkened it a bit to set it further into the background, wouldnt that give you more separation between glass and background?
and if that just mottles and warps the height of the glass, then perhaps another method for getting some separation in the depth of the two planes?
I concede defeat..... smile:cry: smile;) smile:D LOL....
Good idea.....definitely would be more like glass.....
Yeah, maybe like inside the glass block....
ahimsa
Filters: 41
Variation 7 looks like it could have medical gum under it, you know, like for smoking. Pretty nice filter. smile:)
Good suggestions Ron - adopted + other improvement - resubmitted - thankyou smile8)
smile;) smile;) smile;)
I concede defeat I'm so very wrong again
smile:devil: smile:D
ahimsa wrote:
medical gum
interesting thought smile;)
ahimsa wrote:
Pretty nice filter
smile:love: smile:beer:
Sample of mod................smile:)
ahimsa
Filters: 41
That's actually better than the default. smile:)
by george, i think he's got it! the image now looks correct, carl, like it's under the glass instead of partially in it. well done! what'd you do to it?
ronviers
lighter/generalist
This looks great Carl. I really like how you blurred the refraction then blended it back with screen. It really does look like glass. smile:)
@ronviers
I'm not convinced.... smile:dgrin: smile:dgrin: smile:dgrin: LOL..... JK.... smile:)
Been working on giving more depth to the bricks and I've added mortar, this has slowed the filter right down to 2.25 min on a quad so will have to speed up before resubmitting - if I get rid of the mortar it's alot faster smile:|
Love the filter, but not thrilled with the smooth mortar......maybe a rough mortar would look better..... smile;) smile:)
ronviers
lighter/generalist
I really like the mortar - I think it is much better with it. I am not sure what glass block mortar is composed of but to me it looks accurate. Too bad about the performance hit but isn't that the way it goes. Have you tried Sphinx.'s Forced Buffering Optimization on it? I have not had time to look at what it does but it looks very interesting and I would like to give it a try on a couple of mine one day.
Good luck on the optimization. smile:)
@ronviers
ronviers
lighter/generalist
We have not agreed about anything so far. smile:D
@ronviers
We agree to disagree..... smile;) smile:D
Carl, just for sheeeots n' grins......try using mortar like the grout on this filter......
http://www.filterforge.com/filters/4351.html
Ok here is a version with gritty mortar
I'm really not sure which is better smile:|
ronviers
lighter/generalist
I think with the finer mortar the gaps should be smaller. Which is faster?
I just did a google images for 'glass blocks' and it looks like a lot of people put what appears to be lumber in between them.
@ronviers
Thinned it and added a bit of irregularities - what do you think smile:)
ronviers
lighter/generalist
I like the smaller gaps a lot better. Can the user control the color of the mortar?
http://www.all-westglass.com/images/92.jpg
http://www.luxcrete.co.uk/main/blocks...system.htm
I really like glass blocks. When I get rich I want a bunch of walls made of them. smile:)
@ronviers
I see what you mean with the super structure and the grout is white a smooth - readjusted - grout is slightly wider - I think this works best out of the three smile:?: smile:)
Good tips ron smile8) in these grout versions I've added a second refraction to give reflections on the inside walls smile:)
and I like the atmosphere glass bricks create a car made of them would be pretty cool smile;)
ronviers
lighter/generalist
Something about the lower left quadrant of that last sample looks so perfect. The filter may work better on images with lots of shadows. smile:)
Yes. Or helicopters! smile:D
@ronviers
I like that last sample much better without the lumpy grouting.....excellante!!! smile;) smile:D
Yes you were right I'd over lumped, you know how it is, one starts to over endulge in lumps for the pure pleasure of it, you just can't say no to another lump smile:D
18 unregistered users.
