ahimsa
Filters: 41
Circuit Board - Printed by LilBlueSmurf
http://www.filterforge.com/filters/4973.html
ahimsa
Filters: 41
You did really good on this. Glad you submitted it. smile:)
ah, cool. you got it done! did you get the L-shaped chip worked out?
LilBlueSmurf
Filters: 7
No, I thought I got the chips worked out better, but I just don't think it's gonna happen. Unless there were something like "solid fill with darkest color" for tiles, because even when I blur/threshold then use that for the tiles it only works sometimes since tiles fills are averaged. Right now the thing is pretty much just for people to look at or filter makers to play with because it was taking a lot of my time and since I don't own FF I can't really do that if I want to try for 3 HU's. smile:( If I end up getting a copy then I'll go back to it and dig in.
Looks as good as the examples you posted. smile:) There seems to be a big section of stuff that isn't wired into the filter though, not sure if that would be slowing ir down some, or if you meant to plug those in somewhere ?
LilBlueSmurf
Filters: 7
If I understand right, extra doesn't affect the render, just makes the filter file a bit bigger. That was just some experimenting to get copper coils, more for old style boards, but I forgot it was in there when I submitted. smile;) It's really pretty slow no matter what with all the blurs offsets and feeding things into everything to attempt to eliminate overlapping objects. It can be sped up a lot if you don't worry about that. smile:(
Cool!!! smile8)
Vivian C.
FilterForge Poser
Filters: 4
Very cool looking! Great job!
18 unregistered users.
