ronviers
| Posted: December 28, 2007 6:56 pm | ||||
| ssamm |
Nice effects. I'm a fan.
StevieJ, I noticed that with your Highlights, Midtones, and Shadows controllers, you end up using six blends. In case you hadn't thought of this, you could alternatively use a Multiblend component -- which apparently would only use 3 blends. I suppose any speed difference, here, would only be minimal -- but I thought I'd mention the idea... I even made a personal filter comparing your 6 blend method with some potential multi-blend methods. I'll attach the filter below... (If it doesn't make sense to you, then no problems -- I think I'm just being obsessive-compulsive a bit. levels test.ffxml |
| Posted: December 28, 2007 8:06 pm | ||||
Thanks ssammm, glad you like it.....
Yeah, I tried the multiblend method.....and although theoretically it should be the same.....using all the blends seemed to work better. I think it's because of the blending in stages..... You actually gave me a nice B&W sillouette idea from that..... .....and thanks for the bump, Ron Steve
| Posted: December 29, 2007 11:26 am | ||||
![]() Steve
| Posted: March 17, 2008 11:46 am | ||||
| Posted: March 17, 2008 6:22 pm | ||||
Thanx
No......just got one today.....have you been getting mine??? Steve
| Posted: March 17, 2008 11:58 pm | ||||
