LilBlueSmurf
Filters: 7
Color Bubbles by LilBlueSmurf
http://www.filterforge.com/filters/4913.html
LilBlueSmurf
Filters: 7
My first filter, woo hoo! Feedback, crits, suggestions, would be appreciated since I'm somewhat in the dark.
looks great. i hadnt even caught the little extras till i read the description smile:)
Hey good first filter smile:) a bit of feed back [ you did ask smile;) ] the offset for the shadow is causing you bit of problem without studying your filter you may have to offset and duplicate components earlier in the tree smile:)
LilBlueSmurf
Filters: 7
Wow, when I used the filter on my computer I somehow don't have the odd cut off / tiling issues that show up on the site. I guess I need to figure that out as it can pretty much make this useless when it shows up. smile:evil: smile:?:
Good first filter LilBlueSmurf... smile:)
I know when the preveiws are rendered for the site Seamless Tiling is turned on. When I opened up your filter the seamless tiling was turned off...You can render some different presets with the seamless tiling turned on and adjust the presets for the site and resubmit.....
Fixed problem nicely, was it the seamless tiling smile:?:
LilBlueSmurf
Filters: 7
No, the problem was that the shadows didn't get scaled correctly along with the bubbles so I had to add in another separate scaling for them.
I would recommend distortion from the bubbles, along with toning down the reflections a bit, otherwise, I love it anyway!
14 unregistered users.
