Lucato -- this doesn't look like a metal, because metals have metallic reflection (check the Metallic parameter of the Result component).
Lucato
FF addicted
Vlad, I'm sorry, but It is there (check the Metallic slider in the tab settings which controls the Metallic parameter of the Result component).Unless you think It should be fixed as 100 and remove the slider. Actually the intention was to do this way where users can have control over the metallic reflection. Anyway, I will improve the 'factory' presets reflection and lights and resubmit. Thanks for the warning.
Lucato
FF addicted
31 unregistered users.
