| Constantin Malkov | ||||
| Posted: December 12, 2007 3:42 am | ||||
| Constantin Malkov |
I like V2 - no questions!
And very good speed. |
| Posted: December 12, 2007 3:46 am | ||||
actually I just resubmitted with no 2 as lead
I had the filter rejected two times because it was too slow, but I didn't feel that I could sacrifice anything, so I added a little optimization trick which uses blurs (!) to speed up rendering (only works for rather low frequency renderings) - thats why you see a slow first row rendering (the bitmap buffers need to render internally). I just checked in a snippet that describes this method.. |
| Posted: December 12, 2007 3:51 am | ||||
ahimsa
Strange, but very cool filter. I like that default preset the best. Looks like some sort of putty.
| Posted: December 12, 2007 5:20 am | ||||
very photo-realistic! i'll be studying this one, sphinx. nicely done!
| Posted: December 12, 2007 8:35 am | ||||
| uuk |
Nicely done,
i like the black colored presets.. they remind of car tire rubber. Nice work! |
| Posted: December 12, 2007 8:16 pm | ||||
Very cool - blur speeding it up I'll have to have a look at that
| Posted: December 13, 2007 1:24 am | ||||
| Conniekat8 |
Beautiful filter! It renders reasonably fast too.
But seriously, I don't mind waiting a bit to see something this cool render out. I'm going to try it's bump map in Zbrush |
| Posted: December 13, 2007 12:39 pm | ||||
I missed this one......nice work!!! I love the texture and lighting you have created in this one
| Posted: December 13, 2007 12:41 pm | ||||
ah, editor's pick. well deserved!
folks, this one is an extremely good one to study for how to do lighting and textures. this is as near to photorealistic of any filter i've seen in the library...ANY! If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: December 13, 2007 2:04 pm | ||||
| Conniekat8 |
This is more of a filter making question, but it's relevant to this specific filter... I think
I'm curious, if someone wanted to have double pairs of stitches running close together, how would you go about that? I was looking at where perlin noise was plugged into profile gradient, hoping I could offset a phase of the gradient a little bit, then blend them back together, but no luck on getting an offset. I'm trying to make double stitching that is often found on upholstery or jeans Elp... Yelp... Help |
| Posted: December 14, 2007 2:43 pm | ||||
Do you have a sample pic? Also check out this my Winding Trace as it uses the same concept, but in a more customizable fashion (basically it "winds" everything you feed it)
| Posted: December 14, 2007 4:11 pm | ||||
| Conniekat8 | ||||
| Posted: December 14, 2007 6:32 pm | ||||
| jffe |
Nice, reminds me of the cushions filter but with it's own style and take on that theme.
jffe Filter Forger |
| Posted: December 14, 2007 9:49 pm | ||||
Conniekat,
I get the idea now.. the winding method will not make the strings dive down into the material, it will only wind the string composite strings them selves. But it looks like you're on track there.. I'd first make a nice fine winding string, and then multiply it with a repeating gradient mapped with an inverted peak curve (the impulse curve should work well here), which very much looks like you're doing here.. |
| Posted: December 15, 2007 3:28 am | ||||
| Conniekat8 |
Thanks Sphinx, I think I'm slowly getting there
| Posted: December 17, 2007 11:59 am | ||||
KGtheway2B
Just wanted to give you a belated thanks. I use this one all the time. It's great.
| Posted: September 1, 2008 3:00 am | ||||
umy
Posts: 1 |
Mind if I use this as a texture?
| Posted: April 5, 2009 10:45 am | ||||
No problem, thats why its there |
| Posted: April 6, 2009 2:13 am | ||||
15 unregistered users.
