Good work. A few comments:
1. The default look is too dark, even despite the fact that the Lighting is set to 355 -- I'd suggest to use brighter colors for the default preset.
2. The both color controls have the same names, I suggest to rename them.
3. There is room for speed improvements -- for example you can eliminate the Blur components and use a Perlin Noise with low Details setting instead of it.
4. The look is not so good when you set the Size slider to 600 -- I suggest to work on the Noise component to make sure they look good on large Sizes.
Other than that, good work!
I've made a few suggested modifications (not final, just to show my ideas above):
treebark.ffxml
I hadn't noticed the comments in forum-form up till today... will update filter soon...
gr...
Ron
30 unregistered users.
