Messages 1 - 45 of 48
| Posted: November 20, 2007 4:55 am | ||||
Nifty -
| Posted: November 20, 2007 4:57 am | ||||
yup, that's freaky cool. i might even do some art with this.
| Posted: November 20, 2007 2:13 pm | ||||
Nice one, Sphinx!
| Posted: November 21, 2007 6:40 am | ||||
| voldemort |
Great effect --maybe its just me but the cappacity to preserve the source photo's details would be nice--I modded my own version to reflect this since I actually had a project this filter fit the bill for perfcetly in many ways and by preserving the detail the effect is quite eye popping
might want to add that as a check mark option for the end user or a slider to control detail levels like I did for my port lets all whine for a wine port |
| Posted: November 21, 2007 9:39 am | ||||
I don't follow..could you elaborate? Is is the noise distortion or perlin noise detail sliders or something else you are talking about?
| Posted: November 21, 2007 9:48 am | ||||
| voldemort | ||||
| Posted: November 21, 2007 11:30 am | ||||
| voldemort | ||||
| Posted: November 21, 2007 11:39 am | ||||
| voldemort | ||||
| voldemort | ||||
| Posted: November 21, 2007 11:40 am | ||||
| voldemort |
Dont get me wrong your default version gives a great illusion of depth where as mine lacks the same depth but the option would be nice to use either method
I simply added a few options Pre deform --map the photo to the shape some what ****refraction 0.1-0.75 (took the hight map and reduced contrast first) ****offset 2-25% (all controlled with one slider) Darken recesses --a blend of both your method and mine pre-sharpen image **** sharpens the image prior to deform --helps with details still showing invert height --instead of veins --recesses intact method do I deform or simply use a height map height style allows you to choose what chanel to use as source (default was b but some photos the other channels worked better) Fiber Image-b.ffxml lets all whine for a wine port |
| Posted: November 21, 2007 11:46 am | ||||
| voldemort |
i have been working --only off and on -- on a port that likes you takes several layers initially and deforms the photo slightly at pre blend stage so when the blend occurs it realy implies differnt directions and depths not done with it yet though but if you would like I would be more then happy to upload it in this post for you to look at
| Posted: November 21, 2007 11:55 am | ||||
Looks interesting - like something is going on "under the skin" .. actually reminds me of some of the early stages of the development (before I adjusted the perlin contrasts).
I will check out your example and see if it fits in for an update (I might simplify things a bit..), you mention "offset" and "refraction", but wont that break the seamless processing?
Sure |
| Posted: November 21, 2007 12:13 pm | ||||
| voldemort | ||||
| Posted: November 21, 2007 12:46 pm | ||||
| voldemort |
Like I said Im combining the two and that one isnt ready yet but here is this port if you loke
Spaghetti-b.ffxml lets all whine for a wine port |
| Posted: November 21, 2007 12:48 pm | ||||
| voldemort |
but wont that break the seamless processing[U]
if your refering to seamless tile --no but if you are refering to non uniform images that are rectangular hasnt broken any ive thrown at it since you asked unless you set the deform really high but the majority where fine lets all whine for a wine port |
| Posted: November 21, 2007 12:58 pm | ||||
volde, those first few you posted look a lot like sprayed fiberglass. the 'strings' are a bit long, but nonetheless a definite fiberglass coating look.
i also like the inverted ones. reminds me of the 'wormcraft' filter a bit. If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: November 21, 2007 1:30 pm | ||||
| voldemort |
well even if he dosnt plan on any changes to his ""considering how excellent his is allready"" they are there for download --
and yeah I hadnt though of fibre glass but your right lets all whine for a wine port |
| Posted: November 21, 2007 1:56 pm | ||||
yup, good filter and it's given me a couple of ideas. i may have to study this one under the hood.
| Posted: November 21, 2007 2:14 pm | ||||
Allright .. I've been looking more closely at your modification, and it would be a great addition to have this coated fibers like functionality.
The refraction module however seems to add unpleasant noise even with very gentle settings, and the texture mapping style IMO works much better with the offset trick alone. Both the refraction and offset mapping method try to do the same thing: map the image on the bump surface.. so why not just stick to the better one of them? |
| Posted: November 21, 2007 2:32 pm | ||||
| voldemort |
here is a better example of the second one---and Ive found that to much offset -mapping distorts the base image and that to much refraction spoils it to so thats why I tend to combine the both of them for the effect --and yes you really do have to keep the refraction under control --powerful stuff man, powerful stuff
![]() lets all whine for a wine port |
| Posted: November 21, 2007 2:37 pm | ||||
ok.. but that sounds like a general statement... I'm talking about the actual case here - the filter produces high frequency patterns - the refraction just turns it into sandpiles Moreover theoretically speaking refraction is not what we want to achieve here (there's no light being refracted) The offset mapping is not nearly as drastic here - however the profile gradients could pose a problem with non square images and more extreme settings in general - I think I'll add a litte trick to avoid problems |
| Posted: November 21, 2007 2:51 pm | ||||
| Posted: November 21, 2007 3:02 pm | ||||
| voldemort |
if you look at your example the life preserver is a little stretched in both axis no longer quite round ---that was what I was refering to and why I use a little of both as far as the refraction goes Ive found that if you use a brightness-contrast component and turn contrast WAY down then set your refraction slider to only go from 0.1-0.5 it works okay then they still have full slider control without the sand pools lets all whine for a wine port |
| Posted: November 21, 2007 3:21 pm | ||||
Okay I see what you mean - its because the offset is based on straight horizontal and vertical offsets.. I will experiment some more with this (trial runs out tomorrow..sigh)
I don't see how running it through refraction helps that.. it only hides it? |
| Posted: November 21, 2007 3:42 pm | ||||
| Posted: November 21, 2007 4:25 pm | ||||
Personally, I like the original look best. I think you should keep it.
| Posted: November 22, 2007 6:11 am | ||||
Yep, the surface mode will be optional..
| Posted: November 22, 2007 6:40 am | ||||
| voldemort | ||||
| Posted: November 26, 2007 5:20 pm | ||||
| voldemort | ||||
| voldemort | ||||
| Posted: November 26, 2007 5:24 pm | ||||
| voldemort |
Ill be uploading a snippet tommorow if you want to use it--if you dont mind I would like to use your spaghetti filter as part of the snippet to illustrate the power of this mehtod
| Posted: November 26, 2007 5:25 pm | ||||
Looks good! Glad the diagonal method worked.. my trial ran out so I couldn't work further on the idea. Drop a note about the origins of the things you use and its fine with me
| Posted: November 26, 2007 5:43 pm | ||||
| voldemort |
couldnt have worked without your addition
You know Ive got 4 of my 20 reward points left over if you need some --I dont know if they are transferable or not --You had just started and I noticed how unique and clever your ideas are hate to see them wasted --might ask the FF team if its possible to transfer points if so I hereby state those 4 points as yours now lets all whine for a wine port |
| Posted: November 26, 2007 5:52 pm | ||||
| voldemort |
Got to thinking about my offer --If you can eventually I would like the 4 points back if you earn them yourself that way I can loan them again to talented upcomers so they can keep developing
| Posted: November 26, 2007 5:59 pm | ||||
volde, on that image, the first of the three, where did you add the image components, to the perlin noise, background or somewhere else?
| Posted: November 27, 2007 1:13 pm | ||||
| voldemort |
I fed the image directly into the offset components---its in my new snippet
http://www.filterforge.com/filters/4780.html in the above example though I set it at maximum values lets all whine for a wine port |
| Posted: November 27, 2007 2:07 pm | ||||
| voldemort | ||||
| Posted: November 27, 2007 2:22 pm | ||||
| voldemort |
if so here is a modded version of the snippet that does this but takes longer to render --the snippet was simply to illustrate the method
remapper-snippet--bb.ffxml lets all whine for a wine port |
| Posted: November 27, 2007 2:23 pm | ||||
| voldemort | ||||
| Posted: November 27, 2007 2:33 pm | ||||
| voldemort | ||||
| Posted: November 27, 2007 3:00 pm | ||||
hehe, poor sphinx, we're ripping it to shreds
here's a stripped down version of the original. renders a lot faster but not nearly the depth. Spaghetti ssphinxmorphero rev 1d2.ffxml If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: November 27, 2007 3:40 pm | ||||
Wow!!! This one looks really interesting!!!
| Posted: November 29, 2007 12:54 am | ||||
Sphynx, I think I read that volde was using his HUs to get you a copy of the program.....if not, then you can have three of mine to get it.....and I will contact FF and make it happen......so let me know.....
| Posted: December 4, 2007 11:47 am | ||||
interesting... between jffe, volde and steve, there is a growing 'patron of the arts' program going on here. fascinating
| Posted: December 4, 2007 1:23 pm | ||||
19 unregistered users.
