Miavir
The Cat who walks through Worlds
Rusticated Quoin by Miavir
http://www.filterforge.com/filters/4721.html
In ancient Egypt, Cats used to be revered as Gods.
Cats have never forgotten this.
And rightly so.
Miavir
Some additional notes that I couldn't put in the Filter:
You can make the quoin take up the whole space by setting 'Bgr Select' to 6.
There are two sets of bevels available for the Quoin, one for the edge, and the main one for the center. The main one is also affected by the Inset settings.
Edge Enhance enhances the edges of the main Quoin only, and can be turned off by setting it to 0.
The rustication forms a rectangular band, the Width parameter sets the width of the outside of the rectangle, while the Inside Width sets the width of the inside area not affected by rustication. If Inside Width is greater or equal to Width no rustication will show.
The shadow stuff knows nothing about what the main direction light is coming from is, at least as set per lighting, so you should match one to the other by hand.
Finally, if you don't know what a Rusticated Quoin is (I didn't until I started researching for this Filter smile:) ) have a look here and here.
And rightly so.
Arkanoid/Break-Out anyone? smile;) smile:D
garbanzo
Filters: 58
all the old buildings here in downtown budapest are made with big blocks like that. you did a great job capturing the different forms and patterns that are most common. great filter!
Miavir
Arkanoid/Break-Out anyone? smile;) smile:)
Sudden stunned silence,... then ROTFL. Yeah, never noticed that smile:-) But hey, if it makes you play with the filter I'm all for it smile:)
And rightly so.
Miavir
Ooo, and I was never there. But hey, have a look at the less common, and show them to me here, maybe we can get those too ? smile:D And as always, glad you liked this one, it seems to be more liked than Cheqs smile:)
And rightly so.
25 unregistered users.
