| Posted: November 13, 2007 5:31 am | ||
Here are some results of the new version:
Before
After
Before
After
I know there is another similar filter, Color Cast Removal by Ken, but all I get from that one is an image with the negative color cast.. The "algorithm" used in the new version, is an adaption of a technique I use in Photoshop. If you want to try out your self, here's a good example of bad color cast: http://www.khiba.com/PSP/Spring02/colorcastdog.jpg |
| Posted: November 13, 2007 5:43 am | ||
If anyone has a bad color cast picture that doesn't work out well with this filter, I'd like a sample of that pic so I can finetune the filter
Gradient casts probably won't work well, but I have some ideas in that regard.. |
| Posted: November 13, 2007 9:47 am | ||
New version gives better control over saturation brightness make-up (see update details).
The horse image can be adjusted much better now, notice how the background is much less over exposed:
(This was made using preset 8, variation 7) |
| Posted: November 14, 2007 6:57 am | ||
yup, that's better. the horse is also better, not as much of that white fog/haze on him.
| Posted: November 14, 2007 9:19 am | ||
13 unregistered users.
