garbanzo
Filters: 58
Coloured Pencil by ScaryKitty
http://www.filterforge.com/filters/4693.html
garbanzo
Filters: 58
ooh, very nicely done! that first preset is wonderful. my only suggestion would be to add a slight blur to remove some of the sharper details before applying the effect, it's be more realistic.
Rawn (RawArt)
Texture Artist
Filters: 105
I like this one alot
Rawn
ScaryKitty
This is as Normal as I get...
Filters: 40
Thanks, folks! This was an accident that happened while I was working on "Painterly Effects." smile:D
Well, if you move the "soften image" slider to the right, the edges are a bit blurred. Is this what you meant? If so, do you think I ought to have allowed a greater range of softness? If not, well...what did you mean? smile:blush:
Here's an image with the edges softer:
Kat
"Listen, gotta dash, things happening. Well, four things. Well, four things and a lizard." -The Doctor
ScaryKitty
Filters: 40
This version has more detail, but I think it looks good in black and white, too. smile;)
Kat
garbanzo
Filters: 58
sorry 'bout the confusion i was a bit too hasty to post, i looked over the controls and couldn't find a blur component, but as you point out, there is one. it's just right smile:)
hi kat,
always looking for painterly effects and this one is pretty cool. i've got one bug-a-boo with it, however. your stroke changes are pretty angular. i looked inside the filter and added one component to try to reduce this just a bit. right after the blend you use to get the 'crosshatch amount', i added a noise distortion and turned the distornion way down to 10. this puts some curvature to the brush strokes... just a bit to get away from that sort of mathematical, computer made 'brush stroke' effect as opposed to the painter's hand.
but, regardless of those changes, i do like this and have marked it in my favorites.
ScaryKitty
Filters: 40
I know what you mean about the precision of the strokes. When I was first building this, I put in a noise distortion component -- somewhere -- but didn't like the results, so I took it out. After reading your comments, though, I went back and put it where you said you did and limited the values, and now I like it a lot. THANKS! smile:D
I did find that that longer strokes tended to look "better" when the distortion was low, but that shorter ones could take higher values, so I added a slider to that component so the user could decide.
Thanks again, dahling! smile:D
Oh, garbanzo? I increased the upper limit of "Image Softness," so now you can have even softer sketches if you like (though of course you can still keep it pretty subtle). smile:)
Kat
garbanzo
Filters: 58
thanks smile:)
you're velcome, cara mia smile:D
Anomaly
Greetings smile:) I just used this filter for the first time and i was totally thrilled with the results! Thank you !! smile:D
ScaryKitty
Filters: 40
Thanks, Anomaly! I'm glad you like it!
I see you don't have any filters listed -- will you be creating some for us, or are you more of an end-user? Regardless, welcome to our little party! smile:D
Kat
Artress Design
Filters: 24
Oh wow! Love it. smile:D
Northernshadow
Filters: 19
Really love all the stroke variations! Excellent! Yep, this is one I'm going to use. smile:D
Sherry
