garbanzo
Filters: 58
LCD Circuitry Board by Sphinxmorpher
http://www.filterforge.com/filters/4664.html
garbanzo
Filters: 58
this very, very cool! i liked your circuit board already, and with this you really captured the LCD look quite well. and the interface between the two here is very clean and crisp. well done, and thank you!
garbanzo
Filters: 58
it would be nice if you could add a slider to the brightness/contrast control you use when making the screen. the one plugged into the 3 color gradient. messing with that changes the vignette around the screen and makes some nice variations.
i love the way you pulled that screen of by the way, very clever
Thanks for your feedback.. smile:) I'll try out your suggestion - I also need to fix a problem with non square images - I'll check in an update later..
That circuitry board need some microchips.. been fiddling with that .. not easy smile:?:
garbanzo
Filters: 58
ah, the non-square image issue. unfortunately with the way you use gradients that will not be easy to solve.
for microchips maybe use a 'tile' set on 'solid fill', with no margins or bevel, then map a noise, maybe a stretched perlin, to the 'tiles' part. send this to a 'threshold' and you have your basic shapes. from there it's just a matter of being creative and making them look pretty smile:)
Sphinx, how about a spin-off filter focusing on 'just' the LCD display look?
Rawn (RawArt)
Texture Artist
Filters: 105
I second this idea, I think that would be really cool
Rawn
i dont even recall seeing this one before. purty cool smile:)
Me either - the LCD still a good idea smile;)
32 unregistered users.
