Really cool, your going to get the reputation as the man with balls smile:D
ahimsa
Filters: 41
Variation 1 is definately the best!
It's marble-tastic. smile:D Cool stuff, not sure I need a plasma ball, but I know where to go now if I do for sure. smile:)
ronviers
lighter/generalist
Carl wrote:
the man with balls
Thanks Carl but voldemort has way more balls than me - plus he is the man. smile:)
Thanks ahimsa - it's easy to make cool ones I just hit randomize to get these. smile:)
Thanks jffe - I needed these for a project I'm working on. I'm not sure how to use them yet but once I get it figured out I will know where to go too. smile:)
@ronviers
Excellent!!! This is REALLY cool, Ron.....I love this type of creativeness!!! smile:) smile:) smile:)
ronviers
lighter/generalist
Thanks StevieJ!! smile:D
I have submitted an update that enables the intensity of the plasma to be adjusted.
Check out how the height map moves the HDRI reflections away from the center of the sphere so the plasma is always unobscured. smile:D
@ronviers
You're welcome, ronviers!!! smile:D
You could improve the electricity jaggedness by using some slight noise distortion.....or better yet, noise distortion on block or tech noise might do it.....but looks pretty cool the way you have it smile:) smile:) smile:)
ah, first geodes and now these! very cool! would never have thought to do this, myself. this may be one i have to look at the guts as i sit here and wonder, 'how'd he do dat?' smile:)
ronviers
lighter/generalist
Thanks for the tip - can you give me an example of what you're talking about? Or maybe just describe it in a little more detail.
You won't need to look at this one Kraellin - the only cool thing about how I did it was using the height map to move the environment reflections so they do not obscure the plasma - most of the rest I learned from you. Thanks! smile:)
@ronviers
hehehe, everyone keeps telling me how they learned from me, but i make crappy filters. maybe i shld learn from me too smile;)
ronviers
lighter/generalist
Yes - for sage advice go read your posts in the 'creating filters' forum - you will keep yourself busy indefinitely. smile:D
You can also open up a few of your filters to check out how original your approach is I think you will be very impressed. smile;)
@ronviers
hehehe, wonderful retort smile:)
First, don't get me wrong.....it looks totally cool as-is.....just making some fun variant suggestions to play with.....
Swap the perlin with block noise (can try techno or pyramids as well) for some corners and jaggedness.....maybe a little stretch on it.....then run it through a little noise distortion for randomness.....then use Ubers radial gradient to eminate the electricity from the center.....
You could also use multiple noise components on a switch for different types of electricity......but might slow up the filter alot. I would suggest making variants just like your orb series.....even one putting the external image in it.......
ronviers
lighter/generalist
Those are great ideas. When I get a chance, maybe next weekend, I will work on some variations and possibly a more realistic one too. I find that as I get closer to reality the render time begins to shoo way up.
Thanks! smile:D
@ronviers
Hey, you had me at "Orb" smile;) smile:D Jerry Megquire LOL.....
ScienceMan
I was browsing this topic and wanted to let you know that I found a pretty good source for plasma balls at www.coolstuffexpress.com - they have a few different models for sale.
ronviers
lighter/generalist
Ain't nothin like the real thing baby.
@ronviers
let's make this a little easier to find: http://www.coolstuffexpress.com/ and off that same site, here's one i like: http://www.coolstuffexpress.com/store...Light.html
more ball work - non square? smile:)
ronviers
lighter/generalist
Carl wrote:
non square
another size pixels thing. I should be crediting someone for the kaleidescope sphere idea but I have no idea where it came from. smile:( I sure didn't think it up - I hate the kaleidoscope.
@ronviers
Nice work on figuring out the size control.....on both this one and the Orbs..... smile:beer:
I love the perty patterns, colors, and glass..... smile8) smile8) smile8)
last resort of scoundrels smile;) but I have noticed it being used cleverly and not as a straight pattern generator smile;)
+1 smile:)
Totte
Ubernerd
Filters: 107
I played with this filter to remove the black around the ball, and mounted the ball on a staff I rendered, a nice magic staff.
purty cool there, totte smile:)
ronviers
lighter/generalist
That is nice! Might be cool to animate the Intensity for a build-up effect. Could even add a glow.
Thanks smile:)
@ronviers
ronviers
lighter/generalist
Hi Totte, I needed one of these with an alpha so just for fun I played around with hdr for the first time. Makes the old one look dull.
@ronviers
ronviers
lighter/generalist
Here it is if you want can use it for something. I will do a better one when I get some more time.
Plasma Ball hdr.ffxml
@ronviers
Totte
Ubernerd
Filters: 107
Cool Ron, I'll give it a go, this one is beautiful!
Hey Ron smile:) Looks cool!!! smile8)
I would suggest, if you really want to go super-realistic with this, use ThreeDee's lightning and radial multiply it around a center ball.....it will be slow (depending on your machine), but worth the wait, IMO..... smile;) smile:)
Love the intensity your getting, looks great smile:)
ronjonnie
Designer / Artist
Filters: 320
Hey Ron,
I LIKE THAT ONE!!
Very COOL!
Have a GREAT day! smile:)
Ron
ronviers
lighter/generalist
Thanks Totte. smile:) If you’re using the monitor I think you are, then I bet it really does look good - those Cinema displays are amazing.
Great suggestion Steve. smile:) Actually it just took a few minutes to turn my mud texture into something that might make up the elements for a better plasma ball. Unfortunately it started turning into a tweakfest, so I’m shelving it.
Thanks Carl. smile:) Hdr changes everything. It’s only just beginning to sink in for me.
Thanks Ron smile:) – you’ve been posting some beautiful and very creative filters yourself.
Btw, anyone is welcome to use this to make a plasma ball on their own.
Lake Bed var a.ffxml
@ronviers
ronviers
lighter/generalist
Here is a shot of the mud lightning - obviously with a little (and by a little I mean a lot) of tweaking, it could be made much better. Then, like Steve mentioned, it could be radially distributed for a plasma effect - tons more tweaking. smile:(
@ronviers
