Messages 1 - 45 of 57
ahimsa
| Posted: October 15, 2007 1:59 am | ||||||||||||||
ahimsa
That looks real! You did a great job on this.
You're still a brat. |
HEHE I've almost milked Dilla scratch snippet to death
No you are |
| Posted: October 15, 2007 2:01 am | ||||||||||||||
ahimsa
You found a lot inside it. Nothing wrong with that. You made good use of that snippet and I think that is what people who make snippets hope for. My snippet has never been used as far as I've seen.
Brat |
| Posted: October 15, 2007 2:06 am | ||||||||||||||
| Posted: October 15, 2007 2:14 am | ||||||||||||||
ahimsa
| Posted: October 15, 2007 2:19 am | ||||||||||||||
had a look and sounds like a challenge
| Posted: October 15, 2007 2:26 am | ||||||||||||||
Interesting one, Carl!
| Posted: October 15, 2007 5:13 am | ||||||||||||||
What is this abomination???
LOL.... just kidding, buddy......looks cool.....Kinda like some kind of alloy alien matallic surface Steve
| Posted: October 15, 2007 12:16 pm | ||||||||||||||
i like the marring and gouging on this, but there's something about the material being gouged that looks odd to me. so, i mostly like this one, but something somewhat artificial looking about the base material i cant quite buy.
| Posted: October 15, 2007 1:15 pm | ||||||||||||||
| uuk |
Very Very Very nice filter Carl,
looks very realistic, But... it is a bit 'Noisy' ( has a little too much noise ) But other than that, GREAT Filter |
| Posted: October 15, 2007 10:52 pm | ||||||||||||||
it not as sharp as i'd like so will work a bit on it when i get a chance
thanks all for comments |
| Posted: October 17, 2007 12:34 am | ||||||||||||||
Yeah, I would take out that light perlin noise layer altogether.....then metal/chrome the hell out of it.....I have just the filter to help you do it ![]() Steve
| Posted: October 18, 2007 12:47 am | ||||||||||||||
KGtheway2B
Very nice filter, I'd love to make a few suggestions though,
I would really like to see you give the diffuse map a bit more of the detail (grain and noise) instead of having the normal map the primary source. If you have good luck adding diffuse detail, maybe you could de-grain the normal map just a bit too. Here's a good example- http://www.filterforge.com/filters/938.html look at the diffuse and normals here, the normal map there is a bit less grainy (which is a better use for normals) but the diffuse has lots of detail. I've noticed this on your other excellent concrete textures: They both look great when rendered from filterforge, but the diffuse maps are somewhat of a let-down, I know you can rock these things crazy good! If you come up with a good concrete diffuse technique be sure to update your other ones too! !!! http://www.filterforge.com/filters/3524-diffuse.html !!! http://www.filterforge.com/filters/3445-diffuse.html Had a look at your other stuff- great collection! (I'd kill for a bullet hole generator that had transparency!) |
| Posted: October 19, 2007 12:11 am | ||||||||||||||
Thanks KG for your post it has prompted me to try understand mapping better [ I'm a traditional 2d artist ] I have adjusted this filter as you have suggested and there is also now controls for varying the noise in the normal map, will resubmit now for Monday
| Posted: October 19, 2007 8:26 am | ||||||||||||||
Hmmmmmmm.....does sound familiar
This filter makes me feel "gouged and scared" .....I think you meant "scarred" on the spelling Just kidding, buddy.....how's the update coming along??? Steve
| Posted: October 19, 2007 10:26 am | ||||||||||||||
Looks much clearer
So, this work is still "scared", eh??? Steve
| Posted: October 22, 2007 9:47 am | ||||||||||||||
KGtheway2B
Big improvement!
If you still have access to the old version send me a diffuse and normal from it. I'll have to show you an in-game comparison so you can see the difference. |
| Posted: October 22, 2007 12:29 pm | ||||||||||||||
mmmm another update I see
Thanks KG |
| Posted: October 23, 2007 6:27 am | ||||||||||||||
well, 'scared' works if you consider those gouge marks as fingernails on the inside of a coffin
| Posted: October 23, 2007 9:24 am | ||||||||||||||
Administrator |
Looks very good on thumbnails, but lacks details on larger renders.
| Posted: October 26, 2007 6:14 am | ||||||||||||||
Hi Vlad, are you talking about a particular map or just the whole thing, I would love to know so I can make better filters and get this one right
| Posted: October 27, 2007 1:21 am | ||||||||||||||
KGtheway2B
Diffuse map:
-Color- You made a step in the right direction with the diffuse changes, but I think you should go a bit further. From what I can tell right now the color in this is determined only by the lighting situation. It has no color besides the little bit of gray in the swirley details. Add a "base" color, gray would be the typical choice for your presets, but who knows, maybe red or blue might look good, you definitely want to give people the choice. -Detail- You are on the right track here with the shifting from normal grain to diffuse grain, but the diffuse is still lacking. I think that if you succeed in getting the normals up to par a diffuse map with less contrast (and more of a basic flat detail) would do wonders. Take a look at this diffuse: http://www.filterforge.com/filters/1384-diffuse.html (Ignore the top and bottom detail, focus on the "belt" in the middle) It's fairly plain, it's got some nifty details here and there but for the most part it seems to have fairly low contrast and some boring colors. If you added some more oomph to the diffuse (even some perlin noise would go a great distance) it would be great. EDIT: Here's a nifty noise you might be able to use: http://www.filterforge.com/filters/4516.html Normal Map: -Too 'Smooth'- Sharpening up the look of the normal map would be a big help for this filter. It would make the cuts and gouges look a bit more like they were scratched instead of smoothed off. Now I'm not just saying pass the normal by a sharpen filter, what you need to do is make the edges look rougher, take a look at this one: http://www.filterforge.com/filters/1478.html that's a good example of one approach you might take. (Although I think you shouldn't go quite that rough, especially for the scratches) I'm gonna submit this before I accidentally close the window. I'll edit if I find it needs better explanation. Also: once you get this one perfect, I demand you go back and re-do your other concrete filters too. |
| Posted: October 28, 2007 2:25 am | ||||||||||||||
Excellent KG, going to work on your helpful advice - Thankyou very much
| Posted: October 29, 2007 1:48 am | ||||||||||||||
Administrator |
I was talking about the default preset. |
| Posted: October 29, 2007 6:57 am | ||||||||||||||
Well it been rejigged and resubmitted for reappraisal - hope you like the improvements
| Posted: October 31, 2007 5:07 am | ||||||||||||||
Administrator |
| Posted: October 31, 2007 8:04 am | ||||||||||||||
Administrator |
For the example above I used the default preset -- I changed the lighting environment to "Forest", and moved the sun to the middle of the left hemisphere.
| Posted: October 31, 2007 8:06 am | ||||||||||||||
yup, that's lookin better.
| Posted: October 31, 2007 11:20 am | ||||||||||||||
Vlad, that one looks excellent. This is starting to look like one hell of a thoroughly battered metal surface!
| Posted: October 31, 2007 11:23 am | ||||||||||||||
now that's interesting, dilla, cause i was seeing gouged and chipped rock. lol. aint that just always the way
| Posted: October 31, 2007 11:36 am | ||||||||||||||
Well, even through my LCD I can smell that the sample Vlad posted above is definitely metallic!
| Posted: October 31, 2007 11:39 am | ||||||||||||||
hehehe.
| Posted: October 31, 2007 12:02 pm | ||||||||||||||
Administrator |
Yes, I think re-specializing this filter to metallic surfaces is a good idea. |
| Posted: November 1, 2007 9:06 am | ||||||||||||||
I agree.
And it definitely needs a name-change (or at least a spelling correction)! --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: November 1, 2007 6:54 pm | ||||||||||||||
| jffe |
The Perlin Noise with the Gain Curve going into it can have the details dropped to 20 without any harm to the look, the 5 Perlin Noise's used to the scratches is overkill, you could just use one, and rotate them with ProfGrads and probably save another little bit of render time there. The Noise Distortion component can have the details dropped to 20 and not really suffer any loss of detail. I don't wanna nit-pick it to death, there's lots of little speed increases possible in this one, which is a good thing, it means it can be made to run much faster.
jffe Filter Forger |
| Posted: November 1, 2007 11:56 pm | ||||||||||||||
I can remap the reflective blurring to restrict.
Yep does look better - will use suggestion
will have a look at that - every new bit slowed it down more and more thanks every one - this one has turned out to be a good learning help |
| Posted: November 2, 2007 10:25 pm | ||||||||||||||
KGtheway2B
Oh HEEEEEL yea!
| Posted: November 4, 2007 1:22 am | ||||||||||||||
Hey Kg Been having new computer internet problem so its taken a while to get through all my emails. You've been huge help with this fitter and for future filters, I owe you one
| Posted: November 12, 2007 12:53 am | ||||||||||||||
Just strolling by... but it is good to see this having become HU!
| Posted: June 1, 2008 6:19 am | ||||||||||||||
yup, nice one, carl
| Posted: June 1, 2008 12:22 pm | ||||||||||||||
KGtheway2B
Carl still owes me some revamped concrete filters
| Posted: June 1, 2008 4:12 pm | ||||||||||||||
yes was happy with that
thanks Craig, I always hoped Crevice would go HU which was all about the same time /Base
I'll have to look back and see what i was going to do |
| Posted: June 2, 2008 2:09 am | ||||||||||||||
Administrator |
Better late than never |
| Posted: June 3, 2008 11:19 am | ||||||||||||||
LOL ok sent update
| Posted: June 4, 2008 7:10 am | ||||||||||||||
13 unregistered users.
