kekorama
I have bought FF and i am totally enthousiastic about it.
But I seem to bump into an alpha problem, probably caused by none other then me. I have managed one time to get it working, but now i seems to do something wrong and i dont know what. I cant save to png, so i used tga.
Can anyone bring me suggestions on how to tackle this problem?
Welcome to FF & the forums, kekorama.
Regarding your problem, you'll have to be way more specific. What exactly is your 'alpha problem'?
[On a sidenote, the proper places for your inquiry would be the "Bugs and Problems" or "Creating Filters" forum areas.]
kekorama
Thank you Crapadilla!
and point taken that was pretty unexplaining smile:) problem is that it doesnt safe the alpha with it but makes the background white or with an image. Don't know how to explain the problem other then this. hope though it will be enough.
[about the posting here, i was under the idea i wrote in bugs and problems :S ]
Are you using FF in standalone mode? If so, go to File > New Image and check your fill color. In order to save out an alpha generated with a filter you need to make sure that the alpha value of the fill color is set to zero. Otherwise, you'd always get a completely solid alpha.
kekorama
bows!
Thank you so much, incredibly stupid of me! finally! Yay! did i say thank you?
Glad I could help. smile:)
