Warhol, 1985 by garbanzo
http://www.filterforge.com/filters/4278.html
Rainbow multi-vision.....cool!!! smile8)
yup, good one smile:)
ahimsa
Filters: 41
Goes great with my blacklight posters and Rawn has created the lava for a lamp so it looks like all that's needed now are some beaded curtains. smile:D
Foxxee
Filters: 61
~Foxxee~
Just have discovered this wonderful and beautiful filter that gives such a great colorful effect and the black outlines conversion that look very good depending on the settings, from fine detail to large black abstract shapes.
The only problem and bad thing is that it does not work with non-square images as it gives weird things, perhaps updating the filter with the new updated components from FF 3.0 could be possible to make it non-square compatible.
have just found again this filter and think is very good and can give surely artistic results and many possible variations in a colourful way
this example is using preset 6
be aware that you should use square source images for the images to keep inside the grid, unless you want some weird or unexpected result
Here is a non-square test of a radial black and white stripes
24 unregistered users.
