Sea Water by Constantin Malkov
http://www.filterforge.com/filters/4141.html
Nice!!! You could go even further with this if you wanted.....adding white crests, etc..... smile:)
onnetz
I'm sure I could find a use for this.. Realistic water is one of the harder things to create in 3d.
It sure is.....I have one that I periodically tinker with.....probably will never get just right smile:)
Foxxee
Filters: 61
A slight transparency slider and distortion for 'objects' that one might see under the water surface would be great too!
I downloaded this as well, one of the better water filters I've seen smile:D
~Foxxee~
43 unregistered users.
