Bright Frames by ahimsa
http://www.filterforge.com/filters/3822.html
I like variation #6 the best, it looks the most 3-D and lit up. I tried a similar look with my Circuit Frame filter, but it probably works even better on yours since it has a bit larger pattern details usually. smile:)
Foxxee
Filters: 61
These are so pretty, Ahimsa!
You sure have a knack for fabric filters smile;)
~Foxxee~
ahimsa
Filters: 41
Thanks jffe and Foxxee. jffe, this started out as a fabric. I forget what the fabric is called, but the default and the solid presets look exactly like it. Usually little girl's dresses are made from this type fabric. I wasn't able to get the sheen though in the tileable version so that's why I made that other fabric filter.
Presidio
Presidio
Filters: 43
Downloaded~ smile:D
Beautiful presets!~
I like the fact that it makes buttons and frames too!
ahimsa
Filters: 41
Thanks smile:)
I am having a filter making block at the moment. smile:eek:
Foxxee
Filters: 61
Hey, Ahimsa, just a thought to share, but I get a lot of inspiration just looking at home magazines. There are lots of little hidden goodies in a picture of a bedroom or kitchen, or even a bathroom. And outdoorsy things all over in the pictures of decorated gardens and yards. Skip the main image they are showing you and start scanning through the rooms around the floors, walls, corners, nick-knacks... you might find something that lights up your imagination smile:D
~Foxxee~
ahimsa
Filters: 41
I think the Big Brother live feeds are causing my brain to gel and that is why I am having this block. smile:D
Foxxee
Filters: 61
That can happen, if you get stuck on those kinds of shows. I don't care for them myself, but use to be addicted to The Bachelor... secret obsession that I had to break myself of because I always hated to see them get hurt by the ladies afterwards, hehehehe... oh dear, ok. I have to go to bed now smile:D
If my suggestion helps you, or try it and see if it leads you to other ideas to get inspired by, let me know ok?
See you later Ahimsa, and have a good day smile:)
~Foxxee~
lol. either of those tend to kill brain cells smile:D
the best cure for 'block' i know of is to go out and look at stuff. look at lots of stuff, filters, the guts of filters, magazines like foxxee suggested... just LOTS of stuff. whenever i get stuck for ideas i just start ripping other folk's filters to pieces or go find a photo gallery site or take a walk or just start throwing components together hither and yon until something pops up and then follow that.
ahimsa
Filters: 41
The hither and yon method is my favorite. smile:D
Presidio
Presidio
Filters: 43
Sending this little wizard to unblock you~ smile:D smile:D smile:D
Abracadabra... 1, 3, 2, ... or was that... 3, 1, 2.. no... no wait a min..
hold on.. smile:D
1, 2, 3...
Yep,,, that's it! Block should be gone!
Presidio
Presidio
Filters: 43
If that didn't work...
try this one...
look into the smilie ... smile:D smile:D smile:D
Block gone yet?
(((Hugs)))
ahimsa
Filters: 41
Yes...I...am...unblocked now...
Today I need to finish uploading my promotion junk. I can't believe how long everything takes me these days.
MysticBlueRaven
Texture Artist/ Cavy Slave
Filters: 75
very beautiful presets ahimsa smile:D smile:D
ahimsa
Filters: 41
Thanks Mystic!
Well, Persidio, your hypnotism worked and I got a filter made. Only thing, I never finished doing my uploads. FF is a drug! smile:D
MysticBlueRaven
Filters: 75
I agree with you there,its very habit forming. Wonder if hypnotism will work for me. I hate it when I get blocked lol
ahimsa
Filters: 41
Dr. Persidio, your services are needed! smile:D
I think the metallic effects are stunningly gorgeous on these.....nice work!!! smile:)
ahimsa
Filters: 41
Thank you, Steve smile:)
Did you update this one??? the presets look different.....better different smile:)
ahimsa
Filters: 41
Nope, same presets. Maybe you were sleepy the first time. smile:D
I'm still jealous that this one is brighter/shinier than my circuit frame one ha-ha. smile:p
ahimsa
Filters: 41
I just wish I could have made this one as a fabric, but it only shines when it is beveled. smile:|
Hmm, if it uses profile gradients, could you maybe make a custom curve for it that has 2 thicker blue lines and a thin white line between then, then use the repeat of that for detail adjustment, to *maybe* trick it into being shiny without the bevel look ? Just an idea, I haven't tried it or anything.
ahimsa
Filters: 41
I don't know. At the moment I just have plans to update what I can on my filters, change the names, upload them, and then take a long break away from here and FF. I don't know if I know how to do what you are suggesting. I did end up making a fabric filter from this, but without the shine.
nice job on this one smile:)
Stevie still likie smile;) smile:) How did you update this one???
