block tunnel by voldemort
http://www.filterforge.com/filters/3630.html
Volde, this one is totally excellent!!! The combination of non-symetry, layering, and depth makes for perfect artistic compositions!!! I'm definitely going to use this one..... smile:) smile:) smile:)
voldemort
voldemort
Filters: 649
thanks smile:)
Your welcome smile:) You have some real "gems" in your recent submissions....not saying anything bad about your other works.....I just haven't had the time to take a good look at all of them yet.....and by these, it's something I seriously intend to do.... smile:)
Yeah, the presets on this look totally wicked amazing, I'm just scared of the render time. <crosses fingers and hopes it's not too bad> smile:D
Actually, render time is not bad at all..... smile:)
Some test pics to create presets.....
smile;)
smile8)
smile:pimp:
smile:devil:
Volde, after taking a real serious "artistic apps" look at some more of your filters last night, I have to say that you have a "goldmine" of undiscovered filters that I can use. Seriously, I could actually run a gallery show entirely of works from just using a few of your filters smile:devil:
voldemort
voldemort
Filters: 649
Thanks StevieJ I havnt been around as much as I would like or participating in the forums as much as I would like either since Im engaged in a lot of other projects Im getting ready to look at your spheres and see if I can fix the offset issue for you
I wouldnt hold your breath as far as counting on me finding a solution though but I will give it a go
Thanx Volde, I really appreciate the offer.....even if you just take a quick peek at it and offer a suggestion that I can try to pursue to remedy it smile:)
voldemort
voldemort
Filters: 649
My first take would be to try a portion of the resize crop and move snippet --in particular the resize --use that on your gradiant then plug it into a tile component
if its 100 size no tileing should occur but you can then tile when reduceing with out the after effects you described --this way the user dose not need to use the size slider in the settings tab but instead will use your sizeing component and should not suffer those problems
now as far as tile offset with a sphere refraction --Ill have to get back to you on that one
still looking into it myself
Thanx, I'm on my way to give it a go smile:)
voldemort
voldemort
Filters: 649
Okay here is where I got
i did 2 versions of the refraction one with the image left alone the other with the source image offsett
then I blended the 2 using a step gradiant and seems to work well
tested the results on 3 differnt style photo and seemed to work fine
Can you post them so I can compare them?
voldemort
voldemort
Filters: 649
give me a bit I only prototyped I didnt actually save anything if you know what I mean
so I will need to make it for you since I only tested components initially
No problem.....trying to emulate it right now.....just wanted to see the right way in comparison to the mess that I'm making smile;) smile:D LOL....
PS.....wondering what you thought of the sample pics that I posted in this string above.....only test pics from setting up presets for intended high-res works.....
voldemort
voldemort
Filters: 649
they look great
ahimsa
Filters: 41
This has a nice surreal quality to it. smile:)
voldemort
voldemort
Filters: 649
Sorry with kids its hard to get much done at night here is the refraction fix I prommised.
the selector goes
org --original
stg1 -first stage of the fix process
final --ofcourse the fixed version so you can compare the original and final output easier
refraction fix.ffxml
voldemort
voldemort
Filters: 649
Oh forgot to mention this is rough of course the mask is off just meant to illustrate the fix is all
Thank you so much for that!!! smile:) You're definitely right....taking the time to help each other out makes this an exceptional place to be.....
Very much appreciated!!! smile:)
voldemort
voldemort
Filters: 649
glad to help if you need any more please let me know
I wish that I could return the favor, but you are clearly well beyond my skill level. If you post a challenge, I'll give it my best shot.....and maybe I'll surprise myself by getting one of them smile:)
voldemort
voldemort
Filters: 649
ask and ye shall receive Ive been trying to get my tile and rotate to do 8 directions useing the same base as the simpler version
here is my latest efforts the offset on the 45% is still off and I cant figure out how to fix it
tile and rotate 8 direction.ffxml
voldemort
voldemort
Filters: 649
Well Ive got a solution it works but it isnt preaty to look at its guts but it renders in decent time
I Just looked at it..... I was trying to use an Int Slider (8 increments) on curve work to try and wrap the offset sine curve phases without limitting their range.....
voldemort
voldemort
Filters: 649
Ill look at that as well where you using a stair curve?
my solution is ugly i pre-rotate the image 7 times then use various layers of alphas to blend tile results --it works
Yes, but I didn't get it.....would only do part of it while leaving some broken areas....
This one begs the need for a 'set initial value' remapping option.....then you would have been able to do all of it with one control on the sine wave curves.....
