Messages 1 - 45 of 68
Foxxee
Filters: 61
Foxxee's Gauzy Curtains by Foxxee
http://www.filterforge.com/filters/3645.html
~Foxxee~
Foxxee
Filters: 61
What the filter looks like over an image.
I used this as a separate layer so I had more control of the color and lighting under the curtain itself till I was happy with it smile:)
~Foxxee~
nice, i like this one.
and with a tiny bit of tweaking, you could have a 'fire' filter there too.
Foxxee
Filters: 61
Really? Never thought of making a fire filter. There's so many great ones already. Might try that out for the fun of it though, not really a 'fire' sort of gal though smile:evil: smile;)
~Foxxee~
ahimsa
Filters: 41
That looks like sheer curtains. smile:)
Foxxee
Filters: 61
ahimsa wrote:
That looks like sheer curtains. Smile
Actually you're right, Ahimsa... I was too quick in naming this that I misnamed it for a textured curtain rather than the sheer curtain it really is. Wonder if it's possible to rename our filters smile:?:
~Foxxee~
ahimsa
Filters: 41
Yes, do it as an update.
Gauzy is fine though. smile:)
Foxxee
Filters: 61
Gauzy is fine though. Smile
Oh I can!?! Great, it was bothering me (but didn't want anyone else to know) that what I meant to name it was what this filter represents, sheer and not gauzy. There is a difference, the gauzy style would be a nice filter to have too, though... or maybe a lace one smile;)
Thanks for the tip, will go do that right now before I forget smile:D
~Foxxee~
ahimsa
Filters: 41
What's nice when you update is that it doesn't change the stats. You know, it doesn't start over at zero. smile:D
Foxxee
Filters: 61
That's very nice to know... but I just tried to re-submit and it won't let me change the name of the filter, just the content of it's description and keywords.
Any ideas what to do now smile:?:
~Foxxee~
ahimsa
Filters: 41
When you edit the filter, make sure you go to the update tab and say what you edited.
ahimsa
Filters: 41
If all else fails, write to FF and ask them to change the name.
Foxxee
Filters: 61
Ok, did that... just asked if it could be changed to Foxxee's Sheer Curtains in the Update tab. Hope that works and doesn't just show up the same name with the update telling everyone else what I wanted it to read as, that would be embarrassing smile:-p
Here's another example of what the filter looks like over a photo. I was thinking of putting up a 'tasteful' back view of a nude in the distance but thought I best in case there are rules I haven't read on this sort of thing... but that is what comes to mind when wanting to use this sort of filter for photography work smile;)
oops... sorry it's so big smile:?:
~Foxxee~
i'm not.
the way you re-submit with a name change is, first, go into the editor and save the exact same filter with the new name you want it to be. then, go ahead and run through the submit process. when it asks if this is a new filter, pick the 2nd option and that's where you'll get a list in which your old filter will show. simply pick your old filter from that list and proceed on.
Foxxee
Filters: 61
Oh darn, now you tell me smile:-p
I've already resubmitted it, but hopefully the staff will understand and either toss it out or do the renaming for me. Hope it's the latter of the 2 smile:D
Thanks for this helpful tip also, Kraellin. Will have to remember this one for sure, I'm bound to need to use it in the near future, hehe.
~Foxxee~
ahimsa
Filters: 41
Sorry I gave you bad advice. I changed the name on two of mine by adding the word update and it went through the way I said. smile:blush:
Foxxee
Filters: 61
ahimsa wrote:
Sorry I gave you bad advice. I changed the name on two of mine by adding the word update and it went through the way I said. Blush
Ahhh, it's ok, Ahisma... if it worked for you hopefully they will like me as much as they must like you to put it through smile;)
But, isn't it great the the guys and gals here are so helpful when you need it!?! I really have a lot of respect for all of you and for Vlad and the support team. They are so polite whenever I've had to write directly to them smile:D
~Foxxee~
ronviers
lighter/generalist
Good job Foxxee - A very nice way to add a layer of voyeurism to any photo – great concept great execution. smile:)
@ronviers
ahimsa
Filters: 41
I should download again so I can have the new name. smile:D
Nice layering effect!!! YWhy didn't I think of that smile:devil: LOL.... You are definitely getting better and better with each filter!!! smile:) smile:) smile:)
Foxxee
Filters: 61
You are definitely getting better and better with each filter!!! Smile Smile Smile
Well thank you, sir smile:D
Better late than never, I have been tweaking some filters, making projects from other's filters and trying to read everything and respond in the forum. Whew... it get to be a little exhausting, but I like it.
~Foxxee~
Presidio
Presidio
Filters: 43
Hi Foxxee...
My last post before I bury myself in FF to make filters... I'll be back later this afternoon or evening (depending on whether I tackle weeds after creating filters... in that case I won't be back till it's dark outside)...
(((Had to bump this filter up in the threads))) BBL
Foxxee
Filters: 61
Ahh, nice of you, but I don't really worry about my filter posts disappearing... eventually, hehe smile:D
See you later today.
~Foxxee~
ahimsa
Filters: 41
Same here. Foxxee, how about a few more samples?
Foxxee
Filters: 61
Hehe, you were reading my mind! You people seem to do that a lot to me... "GET OUT OF MY MIND!!" J/K smile:D
What did you have in mind, Ahimsa? (no pun intended).
I'm sure tomorrow will keep me busy smile;)
~Foxxee~
ahimsa
Filters: 41
A window scene. Maybe with the beach in the background.
Foxxee
Filters: 61
OK, and did you have a filter in mind to see being used?
~Foxxee~
ahimsa
Filters: 41
Your sheer curtain one.
ahimsa
Filters: 41
I think these curtains look like a breeze is coming in through the window.
I need to lay down; I'll look here later. smile:)
Foxxee
Filters: 61
Here's your picture of a nice refreshing beach, Ahimsa smile:)
Hope you're feeling ok?
~Foxxee~
ahimsa
Filters: 41
I'm fine. I see the doc tomorrow and hopefully she can fix me. smile:D
That looks pretty. smile:)
Foxxee
Filters: 61
ahimsa wrote:
I'm fine. I see the doc tomorrow and hopefully she can fix me. Big grin
That looks pretty. Smile
Glad to hear that, hope it's nothing serious.
Well, while I was having the curtains put up by the FF Curtain & Carpet Co. I ran out and played a little! Found a nice writing stick and put my name in the wet sand smile:-p Forgot to get Kraellin's Rubber Face to put a better billow in the curtains though smile:(
~Foxxee~
ronviers
lighter/generalist
Foxxee wrote:
doc tomorrow
I hope things go well. It wish you would get some good news.
@ronviers
ahimsa
Filters: 41
Just thought I would let you know.
Saw the doc, she doubled my blood pressure medicine and one of my diabetes pills. I get the artery doppler next week I think. The one diabetes pill has allowed me to lower one of my insulins, so she doubled the dose of the one pill so that maybe I can get rid of that insulin. I take 5 shots a day plus 3 different diabetes pills. Diabetes is too much fun... smile:puke:
She talked about dialysis again...sure wish she would stop.
She said the blood pressure was the cause of the mild stroke and that it was extremely high that day. So now I have to have my own blood pressure dohicky. My desk already looks like a nurses station! smile:D
ronviers
lighter/generalist
ahimsa that all sounds so terrible. I really wish and hope that things improve for you. smile:| {{{{{hugs}}}}}
@ronviers
ahimsa
Filters: 41
Actually that was a more positive visit than others. The diabetes is causing the problems, the new pill seems to be helping. Thanks to the diabetes I have a lovely range of problems that include my kidneys, heart, and liver. I am legally blind from it as well. Fortunately I still have good circulation and any wounds I get heal.
It could be worse. I know a man that is a brittle diabetic and he is messed up from it. He spends most of his life in the hospital now.
Presidio
Presidio
Filters: 43
A gift for Foxxee~ smile:D smile:D smile:D
Foxxee this sample uses two of your filters and one of David's (no other filters were used).
If someone would help me out with links to Foxxee's other filter and Davids that would be great...
My Notes on Notepad during creation:
1st Preset
Glass Contrast to 52
Anti-Alias Off
Foxxee's 'Through My Window'
Add to Favorites
Preset 3
Transparency slider all the way down
Anti-Alias Off
Add to Favorites
Apply as a layer and add an extra 30 to the layer transparency
Mercury_carbonfiber_bath
By Davidhyno
4th Preset
Apply to solid white background... the bottom half of the filter creates a perfect curtain rod (((quick too)))
Move the rod up to fit on the window
Apply a bunched up layer of Preset 3 of Foxxee's Sheer Curtains to cover the top of the rod to match the curtains.
Apply Preset 3 to Font
End of Notes
Click to view larger image~
Presidio
Presidio
Filters: 43
Hummm...
Looks washed out on Preview...
Needs Ron's Lab Enhance filter to pop the colors.
((The sample shows the basic concept and the filters to use))~ smile:D smile:D smile:D
I could play with this filter all day Foxxee!! LOL Fun to use!!
Presidio
Presidio
Filters: 43
((((Hugs)))
No stress for you! smile:D
ronviers
lighter/generalist
Wow Persidio, that looks excellent!
@ronviers
Presidio
Presidio
Filters: 43
Thanks Ron!!
I bunched up the curtains too much on the rod...
and if I'd have known it would be so washed out when loaded ... I would have added your Lab Enhance to the whole thing...
Headed over to make a sample on one of your filters... preferably an older one because those are past average use stage and need more usage ... any preferences on what I should make a sample for?
ronviers
lighter/generalist
I want you to use the new ones. This is clean-out-my-desk day so you have a lot of new ones that posted this morning to work with.
@ronviers
ronviers
lighter/generalist
By the way, none of the new ones were finished, I hated to do it but I had to post them incomplete. I had big plans for them but it just didn't work out that way. smile:cry:
@ronviers
Presidio
Presidio
Filters: 43
There were some things that were bothering me on the first sample...
Also added the default preset of Ron Viers Lab Enhance filter on the frame and background image~
Like I said... this filter is fun to play with... LOL
Presidio
Presidio
Filters: 43
Okay one more... playing with the same image...
wanted to add some rain on the window with my condensation filter...
(((Could use Steve's filters on your windows... he has some amazing glass... in fact I may do one with Steve's glass before I stop~ hehe
(((I hear ya loud and clear Ron... I still think some of your older ones merit the attention though.. but I'll stay to your new ones if you wish it~ smile:D smile:D smile:D )))
Sorry to hear about loading the half done filters... but I'll bet they are fantastic knowing your attention to detail~ ((((My friends have the most amazing filters))))
11 unregistered users.
