voldemort
voldemort
Filters: 649
Runny by voldemort
http://www.filterforge.com/filters/3427.html
voldemort
voldemort
Filters: 649
I wonder if I should have made preset 2 the default since it illustrates the filter's capabilities better
does anyone think I should resubmit it after changeing presets??
Redcap
Redcap
Filters: 100
Yeah, the current preset is good; however, you do have some other presets which I think are better. Good job with this one.
Cool effect smile8)
volde, glad to see this one. i wanna look at the guts. i tried to do one of these way back, but eventually set it down 'for later'. so, this one intrigues.
voldemort
voldemort
Filters: 649
You know my sentiments on modding my work --have at it I want to see its guts spread out and splattered everywhere smile:dgrin:
yup, am currently modding some of yours already. this one will have to get in line smile:)
voldemort
voldemort
Filters: 649
And you havnt even gottem me flowers once or taken me to a nice resturaunt to eat once--damm new I was to easy smile:D
IM looking forward to seing your results
rofl, see, i KNEW there was a catch! there's ALWAYS a catch! lol.
voldemort
voldemort
Filters: 649
A catch I was starting to get the impression I wasnt a catch but sloppy thirds at the least
smile:blush:
lol. you, the master of distortion? the only 'sloppy seconds' would be if you inverted, offset, distorted and otherwise refracted yourself smile:)
voldemort
voldemort
Filters: 649
Had you checked out Im melting or melt away there where 2 other melt effects I created cant remember their names off the top of my head
cool smile:)
voldemort
voldemort
Filters: 649
inverted
does introvert count im so confused or maybe its bass ackwards????
offset,
well I think banned to my basement office should count there
distorted
well You obviously havnt seen any of my work outside FF
now REFRACTED
gonna have to work on that one
lol.
well, would you like me to show you the mod? i could make a new thread. it's essentially done. just a simple combination of a few of yours as an experiment. not even sure i want to submit it.
voldemort
voldemort
Filters: 649
yes please Ive run a couple like that myslef forinstance the twister fun one I released today and the deform thyself work great together
well, i dont know how well these i did 'work together', but it was kind of an interesting test smile:)
ok, i'll post it in the gallery.
TriniArt
TriniArt
This filter appears corrupt now.(12th April 08) It splits the image in two and inverts the bottom part and places it on top.
Please check it.
Thanks
Arthur.
voldemort
voldemort
Filters: 649
Please check it.
ThanksArthur.
Hmm the only way I could seem to cause this to happen was with the size slider at the bottom --this filter really isnt designed to be used in conjunction with the size slider even my experiments with non square images did not do this till the size slider was moved
Can you upload a copy of the image that this is occuring on
and also tell me if you are using the default presets or not
if you are doing a variation please save one as a preset and upload the copy of the filter to this post then using the attach a file section of this forum --that way I can look and see where the issue is happening
But currently my suspicion is that the size slider is the culprit in your case
again let me know otherwise if that isnt the case
18 unregistered users.
