ronviers
lighter/generalist
Noise slider snippet by voldemort
http://www.filterforge.com/filters/3432.html
@ronviers
ronviers
lighter/generalist
Here is a variation that avoids the profile gradient and the min and max values of the noise component can be used as a 'remap slider' replacement. smile:)
Noise slider snippet mod a.ffxml
@ronviers
voldemort
voldemort
Filters: 649
Just noticed this in my hotmail account --checked it out --only draw back is that instead of completly removing a slider you add one back
the best way I have found to fix this is to adjust the color range with in the noise it self
lets say you want the range 1/2 then instead of black you use a dark gray and a light gray for white etc...
Ive allready done this in a couple filters and works fine
guess I should update the readme with this info or make an example in the filter itself
thanks for the tip though
ronviers
lighter/generalist
voldemort wrote:
you add one back
Where? smile:?:
@ronviers
17 unregistered users.
