Rotting Plaster by Nutsy
http://www.filterforge.com/filters/3258.html
Me like! smile:D
As usual, I'd say ditch the image component, it's a texture! smile;)
The plaster 'rot' should be made a lot less regular IMHO; it is too uniformly spread across the texture (as evident in the variations). Other than that, looks cool!
Nutsy
3D Artist
Filters: 9
Thanks for grabbing that one for me.
I added th image channel as I thought some people might want to have a base texture like wallpaper or some thing. But it can be turned off through a slider.
This is bar far the most complex filter i have made yet. Was a right pain in teh arse. And at one point I filddled with a setting and totaly distroyed the effect. Spent ages trying to get it back smile:D Almost gave up.
Anyway Other than it being too uniform smile:p I hope you like it. smile:D
I make things go band!
A quick & dirty mod... smile;)
Rotting Plaster blatantly crapified.ffxml
Nutsy
3D Artist
Filters: 9
Well thats my filter not getting a chance to go into high ranking smile:p
Nah! It'll do fine... smile;) smile:dgrin:
i like this one, nutsy. a bit reminiscent of 'cracked paint' but different enough to be unique. and i love the lathe behind the plaster.
and lol, dilla... 'crapified'! this is the only forum i've ever been on where calling something 'crap' turns out to be a compliment smile:D
Nutsy
3D Artist
Filters: 9
Crapadilla would it be ok if i add your extra noise map in an update for my filter?
ronviers
lighter/generalist
Very nice Nutsy.
@ronviers
Yes, go ahead!
No need to ask, btw. I don't hold any patents on perlin noise components... smile;) smile:D
ronviers
lighter/generalist
Nice job Nutsy - very realistic. I don't think the image adds. It might be better as a texture but I'm no expert. Good work. smile:D
@ronviers
Worked out nicely smile:) I can see this getting used smile;)
Nutsy
3D Artist
Filters: 9
The image map is there for anyone who would want to keep a texture on the plasters surface like a paint job or some thing.
ah, good. was going to ask you about just that, nutsy. whereas plaster does tend to be pretty smooth, there is always some noise, grain and unevenness to it.
i also like the green mold on some of those presets smile:)
It saddens me to see LU on this, because the filter shows potential! Maybe you should give this filter a total makeover and a fresh start? *hint hint* smile;) smile:D
Nutsy
3D Artist
Filters: 9
Yeah i was a little disapointed when i came to check up on my filters :/
Sadly I didnt get enough high uses. And I already had Demo extended.
As it stands I simply cant efford FF at the moment... Even with the 20% discount ontop of my single high usage discount :/
But the LU is a tad irritating i put a fair bit of work into this one.
well, i used it. i used it in making a texture for a wall in wolfenstein ET. looks great!
