Bridge Support Bars by Darth Axel 007
http://www.filterforge.com/filters/3284.html
Note to self = do a filter with bolts/rivets someday ya loser ha-ha. This one would make a cool medievalistic kinda frame in a way too. Nice work on this one. smile:)
Excellent Work!!! Definitely will be used alot!!! smile:)
i can easily see this one being used in bridge models/objects and that sort of thing.
Good work on this Darth Axel 007. smile:)
Darth Axel 007
Darth Axel 007
Filters: 29
There's still that strange blur in the corners Redcap mentioned earlier. This is an illusion caused by the bolts. I created a blur for them in the height map to simulate that border you see around them. I believe I ended up having blurred it's color map too causing the corners to seem blurred.
I'll fix this ASAP. Thanks for the comments guys. smile:)
Redcap
Redcap
Filters: 100
I was thinking, I would love if you could add the option to add another cross beam, making an x across the filter. Only if you have extra time.
Samantha Fuller
I did a mood of this filter that adds rivets to the plates where the cross beam connects and clips the unused corner and rivets from the plate on the opposite corners. How would i share such an update smile:) smile:?: Also when i lay this over a pure alpha it looks good in preview but i get large areas of bleed into the alpha when i save it. smile:?: smile:?: smile:?:
hi samantha and welcome to FF.
legally, you can alter any filter however you choose. you can even submit those to the library. however, the folks at FF have the final say on what is accepted to the library and some filters have been rejected for being too close to another, thus being a 'clone'.
there is also the non-legal and non-FF considerations. no one likes plaigerism/cloning/ripping off of another's ideas and products. however, there is that notion of 'i've got an idea of how to make this better or different' and that is actually a valid thing. the trick is how to present that idea/product without ripping off or offending someone else, particularly the originator. you've already taken the first step of avoiding that, asking smile:) and we/i do appreciate that.
so, what i normally do when i mod someone's filter is, let them know in here in the forums, check their filter to see if it's gotten a 'high use' (HU) rating and won them a reward because i dont want to pull usage away from their filter if they havent gotten an HU yet and talk to the originator about what they'd like me to do or not. and i rarely add a modded filter to the library, the exception being my 'silver surfer' filter. so, i normally, if the filter has gotten an HU already, post it here in the forums for others to grab.
if their filter hasnt gotten an HU yet, i let the creator know and ask what they'd like me to do with it. this sometimes results in doing nothing and i simply keep the filter to myself for my own use, or, i may send the mod to the original filter creator and let them submit the mod if they want and maybe ask for a nod in the description.
now, none of that is 'official' policy; it's just sort of what i try to do.
i havent seen darth axel around in quite a while, so i dont know if you'll be able to carry some of what i suggested out. so, not real sure what you can do here; maybe send him an email? the filter already has an HU, so you wont be taking a reward point away from him. that sort of leaves posting the filter here or emailing darth or asking the FF folks in the contact form.
good luck smile:)
Darth Axel 007
Darth Axel 007
Filters: 29
Hey, sorry I haven't been on in a while.
It's okay if Samantha Fuller updates it. Thanks for the response Kraellin.
18 unregistered users.
