Hey pretty nifty, good work tripy smile:)
NOTE: some controls are inverted at this point i am not sure how to change that so it might require some experimentation. <----You can check mark *Use Remapping* on the slider or whatever control, and reverse the min/max numbers to invert the control effect that way. Not sure if that's what you meant, but just an idea/tip in case it is. smile:)
nice one, trippin. got any whitewalls?
trippin2k6
Trippin2k6
Filters: 4
thanks guys. Kraellin - what do you mean by whitewalls and jffe- yeah ill try that and post an update if my FF doesent run out of the trial.
trippin,
whitewalls are tires with a white stripe on the black.
Well I was wondering when someone was going to get to this..Another hint also is check out some rim web sellers. There is usually an abundance of styles to chose from..
Tread on the tyrer would be nice smile:)
24 unregistered users.
