Presidio
| Posted: May 18, 2007 1:08 pm | ||
Presidio
Paper Art Frame Version 2 Version 1 is here.
The cat is Pizwit. The photo is copyright to Laura Vitale and used with permission. A plain photo for comparision. Click to view the larger image. |
| Posted: May 18, 2007 1:11 pm | ||
Presidio
Presidio
Presidio
| Posted: May 18, 2007 1:12 pm | ||
Presidio
Presidio
The Paper Art Frame Series is not just a photo frame. It can be used as a background for notes, images, photos, etc,.
This series also combines well with other frames. I've used it with my Gold N Silver Frame filter for this image. I used a light green solid background. Then applied an application of Paper Art Frame 2. Then put a rose on top and some text. (((Merge all layers))) Then I used preset number 7 from my Gold N Silver Frame filter. You could leave as is or you can do this next step: Copy and paste that as a new image. Go back to the original and remove the application layer of the Gold N Silver Frame. Now paste go to the new image we set aside and copy. Paste onto the image we just removed it from but this time keep it as a floating layer. Now we have the new application as a seperate layer. I set a soft edge of 70 and removed the edges of the new layer. This lets the edges of the first layer with the Art Frame 2 filter show thru. Merge and save. Image is lighter then original due to compression and the web browser. Click to view larger image~ |
| Posted: May 19, 2007 9:14 am | ||
Presidio
| Posted: May 22, 2007 11:53 am | ||
Presidio
| Posted: August 6, 2007 2:27 pm | ||
