Presidio
Presidio
Filters: 43
Presidio
Presidio
Filters: 43
This filter supplies you with one quilting square to be applied on a solid background (dark color blast the filter and are not recommened). You can test and find the right color, here are the hex colors for the ones I've tested that turned out okay.
I set my background to 500 x 500
The solid background color I used : #C9CECD
Burgandy's #877273 #BA8184 #F6BABD #C29497
Tan's #BFAE80 #E3D3AC #DABEA3
Turquoise #99CBCF #B5D2D4
Blue's #7BA4C3 #7AB9E9 #BAD8EF
Oranges #E8C5B0
Create your desired squares and resize to 35% or smaller.
Open another 500 x 500 sheet and place your squares together as a quilt. You can make designs here if you like.
Grab a rectangle shape to make the quilt edges and flood fill with one of your patterns or apply the smaller quilt pattern design in the filter.
Merge as one layer
To make stitching use the draw a line and set it to dashed. When all the stitching is done ---------> select all layers and merge as a single layer. Apply my 'Industrial Paint Powder Coat' to the stitches or my Acid Wash filter'.
Merge all layers. That's it.
Now that you have your finished quilt you can apply 'Acid Wash Photo Edge', Acid Wash, or Ron Viers Lab Enhance for different looks.
Here are some web tutorials for quilting you can try... and there are more tutorials for quilting via the search engine.
(((Always check terms of use for that site before using tutorials on the web,,, because terms of use vary with the artist))). My terms of use for my above tutorial----> anything you want can even make your own tutorial with it---> a link to the filter would be nice. smile:D smile:D smile:D
http://www.eastofthesun.com/pi6/quilt.htm
http://www.rosiespitutorials.com/cushiontut.htm (((real cute))))(((and could put text on instead of the heart
http://www.poppyfield.se/quilthangercat.htm (((This is a cat quilt hanger you can hang your quilt on)))
http://kittywompuss.tripod.com/country_quilting.htm ((Could use this quilting filter instead of premade squares---> check her terms of use first though)).
Okay-----> and on to the quilt fashion show.
Click to view the larger image. First up we have a set of 35% resized squares to show the design and detailing... then we head on to the quilts... smile:D
Presidio
Presidio
Filters: 43
Click to view the larger image. (((Put together as a quilt))).
You could make them anyway you wanted.
Presidio
Presidio
Filters: 43
With my 'Acid Wash Filter Applied' as a final finish.
Presidio
Presidio
Filters: 43
And a final finish of Ron Viers Lab Enhance.
Presidio
Presidio
Filters: 43
My personal favorite.
A final finish of my 'Acid Wash Photo Edge' fitler with the blue removed (in the filter settings panel).
Presidio
Presidio
Filters: 43
Another default preset with 'Acid Wash'.
And that's it----------> thank you for viewing~ smile:D
Presidio
Presidio
Filters: 43
Sorry these images are so light---------> compression due to web viewing.
I like the background apps for this one.....very clever and useful!!! smile:)
Presidio
Presidio
Filters: 43
(((Stevie)))((((TY)))) smile:D smile:D
Good for projects---->> But could do an entire web page with it. I'm thinking 'triple table tile code'. I have the code if anyone lurking wants to try it. Would be very pretty~
Persidio
MysticBlueRaven
Texture Artist/ Cavy Slave
Filters: 75
Yoy really out done your self one this great filter smile:)
Zephos
Xyni says "Maximum w00tness!"
Filters: 31
I completely agree! And thank you Persidio for writing such a detailed guide on what can be done with your filter as well! It's quite rare to have such thorough coverage filter documentation these days ^_^ Looks like it's quilting time ^_-
-Zephos
Presidio
Presidio
Filters: 43
Hi Lynn~
(((((Thank You))))) smile:fairy:
Gotta tell you I totally beat myself up making this one~ On preset #2 there is a ribbon that weaves thru the square----> and for the life of me I still can't find the right background color to get the ribbon to come thru when applied. So if anyone finds the right color----> please please let me know. I tested and tested. So there will be a Quilting Squares too with less transparency used. (The sqaures vary on the solid background color they are put on). Great quilting sqaures non the less~ Something for us ladies amongst all the macho ones~ smile:D smile:D smile:D
Hi Zephos~
((((AWE----> Thank You for noticing!!!)))) smile:fairy: Takes alot of extra time to get the package together after the filter is made and ready to ship... *g* so to speak~
Not done showcasing this one yet---> I do want to make a triple tile page for it and link it from here in the comments section. Going to do that with cross stitch as well and maybe a few others.
Jean
LOL Yep quilting time~ smile:D
ahimsa
Filters: 41
I love the softness of this one. You really did an excellent presentation here. smile:)
45 unregistered users.
