Presidio
Presidio
Filters: 43
Presidio
Presidio
Filters: 43
Including an example image for this filter. Originally it was created as a semi-transparent figure to 'put some fun' in some bow ties I'd created with standard shapes for scrapbooking embellishments. Could be used for any project; however especially good for projects created from shapes.
The example image is compressed and resized so the true beauty of the filter can't be seen but gives one an idea of application use.
Example shows the shape used to create the bow ties, the finished bow tie, and the last application with the Emergency filter.
Click on the image to enlarge. The bow ties are not made from public consumption outside of scrapbooking kits I create and are copyright. They are resized and compressed so have lost some quality to show via the comments section.
Jean
Presidio
Presidio
Filters: 43
And a bow tie (full size) by itself... with HLS coloring after the 'Emergency Filter' application.
Jean
Presidio
Presidio
Filters: 43
and one of the smaller ones at full size from the first image.
P.S. Sorry and yes only that one shape was used to create the entire bow tie (except for the center that was a standard oval shape). Have fun with your shapes and see what you can come up with. And when you need a fun filter for them that won't ruin your shading on the image... remember the emergency filter. smile:D
