SpiderWeb by Zoltan Erdokovy
http://www.filterforge.com/filters/2409.html
Way cool!
James
James
Filters: 46
Cool smile:D
wow. zoltan, that's excellent! someone took me up on my request/suggestion. smile:) very cool!
This is really neat!!! Nice work!!! smile:)
wow. zoltan, that's excellent! someone took me up on my request/suggestion. Smile very cool!
hehe I was gonna post that post.
Zoltan:
Very cool filter. smile:pimp:
Zoltan Erdokovy
Filters: 24
smile:) I'm glad you like it.
souxsi
souxsi
This is one of the neatest filters, I love it. Is it possible to get a background optional version? That is the only thing I'd change, the filter itself is wonderful.
Thank you for the hard work!
Zoltan Erdokovy
Filters: 24
souxsi: I've just updated the filter, I hope you like it. smile:)
souxsi
souxsi
Ooooo alpha yay! You so rock thank you !!
gravymac
gravymac
This is a neat texture however I am having trouble with a white rectangle in the middle of every one of the features... Got any suggestions on how to get rid of that? Thanks in advance... Gravymac !!
Zoltan Erdokovy
Filters: 24
Have you tried using the presets as a base? Some parameter combinations indeed does not produce a proper image.
gravymac
gravymac
Zoltan, I don't change any of the presets and it still puts the white box in all of the different designs... It seem to work just fine on the demo life saver ring but it just won't work on my own pictures... It is a super filter and would love to be able to use it but it just won't work for me... By the way it doesn't work for a friend of mine who also has filter forge...
I sent a screen grab to Filter Forge so they could see what I am getting..For some reason I can not add the picture here! Sorry...
Beliria
Hi Gravymac welcome to the land of lost time aka Filter forge smile;) smile:D.
Am thinking its to do with the size, pixels but I maybe wrong. On some it distorts the image if you hit variation so you most likely will need to drag the slider to the right to get rid of them.
You'll have to make sure it is well under 250k in size or the file will be rejected. So do compress away! smile;)
gravymac
gravymac
Thanks, Crapadilla... I'll check the size...
Beliria, thanks for the info... The size of the picture I wanted to use it on was a 1024X768 and the other filters work just fine on that size......
Zoltan I will try a smaller version of the result of using the spiderweb...
Zoltan Erdokovy
Filters: 24
Oh, yeah, the filter was meant to be used ONLY on square images. It was never tested/designed for non 1:1 aspect ratios. What you can do however is make a square selection on your image and apply the filter there.
gravymac
gravymac
Thank You I will try that !!
gravymac
gravymac
Zoltan, that works super... Thanks a bunch... I didn't remember reading that when I downloaded your filter....
12 unregistered users.
