Torley
Posts: 303 |
OilFlame by Zoltan Erdokovy
http://www.filterforge.com/filters/592.html ![]() I'm enjoying using Filter Forge to create http://torley.com/textures |
| Posted: April 11, 2007 1:33 am | ||
Torley
Posts: 303 |
Looks like with the multiple-up modes, you could composite these to create animated flames! I know I've seen a classic animated fire texture in Second Life which is similarly presented, so replacing one of those textures with this could yield great results.
| Posted: April 11, 2007 1:48 am | ||
Zoltan Erdokovy
I never got around to do an animation test, but as soon as I can, I'll post the result.
| Posted: April 11, 2007 3:38 am | ||
Vivian C.
FYI: I used this to create a 4x4 texture for use in SL as an anaimation. Worked great.
| Posted: August 19, 2007 7:04 pm | ||
Presidio
I've used this one too and just luv it~
| Posted: August 19, 2007 8:29 pm | ||
Samantha Fuller
Posts: 8 |
If you Adjust Pixel Size you can control the # of cells, I recommend that you get the right # of cells, check tile box, un-check tile, then reduce # of pixels 1-3 to avoid alpha artifact at botom. Sliders to adjust offset would help here.
Also there is a scary feature of this software. I downloaded this filter, added presets and the program automatically without notice sent them back to the website that was just spooky. |
| Posted: July 26, 2008 9:39 pm | ||
17 unregistered users.
