StevieJ's SolarGlow by StevieJ
http://www.filterforge.com/filters/2392.html
Example #1
Original
Example #2
Example #3
Example #4
Example #5
Example #6
Example #7
#'s 2, 3, 5 and 7. although 1 has some interesting pastels. have you tried doing a pastel filter?
Yup, actually just finished three pastel versions.... I just need to take the time to make presets for them.... I also have two more "SolarGlow" filter verions that are almost ready to submit....and I think you might like them. I don't know what it is, but I really like these solar effects....as simple as they are.....especially using them in post-combination with other effects. It's funny....I never used to like solar effects at all.....maybe because they were plain solar effects without the artistic twists.....
Well, I'm sure you know by now that I explore the hell out of everything that I like..... smile:D
No. 7 look great - for me the sutler effects [ pastels ] sounds interesting...... and thanks for the shots of water smile;) ............. Carl smile:)
explore away!
Thanx Carl smile:) I'm sorry about the water.....and I haven't forgotten about your ongoing problems over there. Has anything changed at all???
Kraellin, yeah, I've stumble into alot of things that way smile:) I just found another neat trick.....putting everything before the final blend and putting the curve work after it. I think that you might like it for your photographic effects.....
cool smile:)
Some other little tricks that I just discovered that seem to work well.....putting all the blend mode work first....then levels, gamma, saturation, and lightness work....then the curve work.....then ending with color and contrast....
Through alot of experimentation, doing the mode work after the curve work was deteriorating the image.....and was much more "cleaner" up front....
I've had a bit of a fiddle with using those little tricks and found they certainly can improve final results smile:) thanks.......... Carl
well, just remember what vlad said... ok, i cant remember what vlad said. but, it's on the wiki somewhere and has to do with one component mapping into another component. there's also a thread in here with what he said. just think infusing one component effect into another.
ok, you probably already know that, but do read the wike stuff on it. it breaks it down better than i can explain it.
Carl, glad that it helped you..... and thank you for confirming the results of my 'mad scientist' experimentations smile:)
Kraellin, no, I haven't read anything about it.....but I'm going to go read it. As you can probably tell by looking under the hood and comparing, I've made all of my filters from scratch without borrowing anything from anyone else. I think that I'm learning it better this way.....and it is helping me discover unique effects that have not been done.....even if they are simple effects. Hey, Vlad's organics I think only has three components....and it ships standard with the software smile:)
well, i'm a shameless pirate. i rip off everything smile:) (though i do try to give credit when applicable smile:) ).
Iye Matie, If it aint broke, don't fix it smile:D
I must say that you are exceptional at giving credit where credit is due smile:)
These solar filters are going to be the death of me.....I just found a much better way to do all of them.....and I am re-doing all of them for submittal. After that, I have quite a back-up of new filters to submit......
well thanks, steve.
a new way to do all of them? re-submitting all of them? wow. industrious.
Yeah, unfortunately (or fortunately.....depending how you look at it smile:)) I keep running into better ways to do things.....which is making me feel like a gerbal on the wheel.....and I can't get off smile:D LOL....
hehe, well, just remember to take a sip at the water bottle from time to time and you'll be fine smile:)
35 unregistered users.
