Swirling Dervish by Rachel Duim
http://www.filterforge.com/filters/15351.html
I have just found this awesome effect filter that makes this great ripples waves that looks very good and I am not the only one because it has won an High Use award.
I think that from the still image it would be seem that maybe if it is animated, it may be seen as if the rain is dropping on the liquid image, will see how it works with animation
After gaining some insight I figured out how to animate this. I will probably release this as an update.
WOW!! This is very well done and now really with the animation it really shines , congratulations
And I have an idea for this to make it even more incredible
Thanks SpaceRay! What is your idea?
This animations created by Rachel is from my point of view and taste, is really awesome and amazing how the flow looks really like liquid waves so well done and I like it very much and is a pleasure and relaxing to see it and admire how the waves move and is able to transform a still 2D image into a 3D anĂ­mated water pool
It is a simple and easy one, and is to duplicate it and have two different results with two different images and then Blend both with a blend mode option.
I have been able to create the double image effect and is even better that what I may have thought
Because not only the image is covered to liquid, the liquid itself is tinted with the second image colors using blend modes
This is the FF Lifesaver and then using the Violet Flower built in image as second image
And if combine the green blue kingfisher shown animated above and then overlay the animation of the violet Flower you can be able to get this below
Later will put here the full animation
here is the animation from the above, sorry that the quality is bad but must be like this to put here in forum
here are a little bigger although it looks worse quality
These GIFs have been reduced and optimized to fit here using EzGif.com from 30 MB 600x600 to 900Kb 200x200
