Squircles Animated by Rachel Duim
http://filterforge.com/filters/16577.html
I think that is really a very good, cool and well done effect and great the animation movement, clever technical achievement
I will test if I could have multiple animated squircles with different images using bomber or bomber plus
I may try the multiple spinning images as you suggested, a good idea. Also, the current "spin" is only of a hemisphere! To do a proper full spin, the image needs to be a 2:1 aspect ratio (and seamless in the x axis) with a square passing through it to create a proper full spin. So I will try a couple of things and maybe post some results here.
Globe test
Right click to Loop
