Animated Pseudo-Depth Spiral by Andrey Mironov
http://www.filterforge.com/filters/16387.html
I really like and love very much this and is very good, creative, unique, interesting, cool and well done the beautiful huge and big downward and perfectly done spiral in such great way and multipliying the source image all along the spiral that looks so good
The animation creates a looped animation but it seems that it is very slow moving at 300 frames
So the one I would expect is with a faster rotating spiral, so really it would show the spiral going animated in a loop downward
So I have modified the frames to 90, but still was slow, so I reduced it to half, 45 and this begins to be better
To reduce and compress the mp4 video into a low quality GIF that is less than 1GB, I have used GIF Maker from Mac App Store that is free with watermark
As I still find it slow, I have used the time multiply available inside of GIF Maker and have put 3x Speed and now really is what I wanted really to have
So to be clear, this one is the same 45 frames rendered above with 3x speed in GIF Maker
The quality is low because is the only way to put it under 1GB for the forum
Instead of GIF Maker you. may use any of the many other GIF or video editors available.
Although as I have I love and like it very much, maybe the Top row of the spiral is getting too much crop and could be seen better, and also be able to show how each one of the cups are filled with the coffee
This the same preset 1 at 45 frames with a scale component added at the end with 0,76 value
And personally from my point of view I prefer it even faster, 3X done in Gif Maker
And also you must feed the coffee machine that is filling the cups with coffee beans (preset 1 with 45 frames and after converted in Gif Maker to 2,5x speed)
To able to make this one correctly I have added a Free Ellipse at the end with big plain Circle at 0.5, so it will cut and crop the unwanted outside rays
