I opened this filter Neon Tech HUD Designer and I only get a black screen.
Is it only a problem in my FF or is it some kind of incompatibility between old filters and the last version of FF? |
| Posted: October 5, 2023 1:31 am | ||
| Posted: October 5, 2023 4:11 am | ||
Thanks CFandM. Yes the problem is there. The uniformity coarse mode seems not to work correctly. We see thick lines selecting "None" and very thin lines selecting "Fine". Then "Coarse", that is in the middle between the two, should show a result in the middle, but it doesn't. It is not a problem of the old component because also using a new component the result is the same. It is surely some change that was done in the main settings of Filter Forge, because with older versions it was working correctly, as we can see from the pictures in the library.
| Posted: October 6, 2023 2:31 am | ||
This post was moved to Comments on Filters. I don't think it should. The issue is connected with the new versions of Filter Forge, because before the filter was correctly appearing.
| Posted: October 8, 2023 1:15 am | ||
11 unregistered users.
