| Posted: April 10, 2023 2:08 am | ||||
also outwards and not only circular
cool and well done conversion of the source image to this kind of distortions and the good thing is that it works also for non-square images, as it could be done only for square images as it is a circular effect Here is the original landscape image made of stripes with FF |
| Posted: April 10, 2023 2:19 am | ||||
| Posted: April 10, 2023 2:28 am | ||||
| Posted: April 10, 2023 2:30 am | ||||
| Posted: April 10, 2023 2:33 am | ||||
| Posted: April 10, 2023 2:36 am | ||||
| Posted: April 10, 2023 2:40 am | ||||
| Posted: April 10, 2023 2:42 am | ||||
using squircles mapping 8 is similar to using squircles mapping 4 (both make a perfect squircle circular effect) but it does it in a slightly different way
See that the spaceray name (bottom left) is not in the same way as the one on the second post above So it will depend on what result you like most from 4 or 8 ( the difference is that 4 is squelched and 8 is horizontal) |
| Posted: April 10, 2023 2:49 am | ||||
In post 4 I have put that it does not apply any distortion, but this is not true, as it uses a slight distortion, sorry that I have seen it later. |
| Posted: April 10, 2023 3:00 am | ||||
I want to thanks also to Rachel for including the notes inside the filter and show the complex math that is used for this clever and well done filter
Additionally and alternatively, if you are using only square images and want to convert it to other shapes than circular, you can also use Shapify v1.5 By uberzev but it does not work on landscape images as it does with this well done filter by Rachel shown here |
| Posted: April 10, 2023 3:05 am | ||||
| Posted: April 13, 2023 10:17 pm | ||||
| Posted: June 7, 2023 12:52 am | ||||
Thanks very much for showing these square examples with all the possible options to choose with that very good grid where can be seen very clear the effect Seeing these examples, I got also the idea of mixing the right spherical result (maybe with shadow) with the left result as a background |
| Posted: June 11, 2023 6:11 pm | ||||
| Posted: June 11, 2023 11:29 pm | ||||
Yes, exactly this was my idea suggested, well done. I think is cool and good. And you can combine different ones from each of the 5 groups on left and right. |
| Posted: June 15, 2023 6:43 am | ||||
| Posted: July 11, 2023 9:21 am | ||||
| David Roberson |
@Rachel,
I was never able to find your email regarding the squircle math. Is there a link or something you can share here? |
| Posted: July 13, 2023 1:45 am | ||||
Just go the filter webpage https://filterforge.com/filters/16430.html
And look for 2 pdf links toward the end of the section or https://arxiv.org/ftp/arxiv/papers/1709/1709.07875.pdf https://arxiv.org/vc/arxiv/papers/1604...2174v1.pdf Math meets art meets psychedelia. |
| Posted: July 13, 2023 2:16 am | ||||
| David Roberson |
Thank you!
| Posted: July 13, 2023 5:28 pm | ||||
Thanks to FF and all FF users for the High Usage award! I was amazed when I realized the squircle pdf's by Chamberlain Fong could be done with gradients and lookup, just in a different numerical space (-1 to 0 to1) vs FF space (0 to 1).
And another example with Rotate Madness squircleized: ![]() Math meets art meets psychedelia. |
| Posted: August 20, 2023 4:24 pm | ||||
