Filters: 712
Geometry Etcetera by Rachel Duim
http://www.filterforge.com/filters/16055.html
Filters: 712
Nice and colorful filter. smile:D
Thanks. smile:) Here's an example using Forge-o-scope images as "colors"
Oh!! You have done It using my idea, and It looks nice and cool. Will see how It works and what can be done
Thanks very much for making It and is much appreciated
Although this was not my idea of how to make It but you have given a new twist and I think is good alternative. For example the idea of allowing to have optional overlapping is interesting and will ser how It works
Also I thanks you much that you have done a version that is not for FF11
This looks great, beautiful and artistic And great idea to use your filter in that way
Nice work Rachel it came out looking pretty good. smile:)
Thanks SpaceRay and CFandM! When I saw the example you provided it screamed Bomber +. Also I knew you aren’t up to FF 11 yet. I’ve got extra reward points if u need them.
I have just seen that this filter got a High Usage award so many people are using it, and this is very good as you deserve it as I like very much it, and is awesome.
Although my original idea for making this kind of filter and the inspiration I got is NOT like this filter and it will not have any black background or empty space between shapes, and it will have tight grouped geometric shapes, and I have been able to make about 50 different geometric shapes to be used created taking example fr om many different places, and using the Totte megaswitch with 50 slots to feed bomber and make the randomization better.
The essential and very important difference between filter forge (FF) and any other software that is able to make this kind of geometric patterns is that you CAN FILL EASILY any of the shapes WITH YOUR OWN IMAGES and replace them easily, as you have shown very well in your example, and this is wh ere FF shines and is above any other I know.
Yes, I is true I have made also a version with Bomber plus, BUT I did not know how to combine the different sizes into one result, and you have made it very well and is a clever and good way.
thanks for the offer of points, but finally this has been fixed, and now I have been able to upgrade to FF 12 Studio so now I can use any filter.
Thanks for considering me and making for a lower version and also is good for other FF users to be able to use it also.
