I discovered already this some time ago but forgot to give thanks and tell about this on how it helped me
This is really very usefull and helpful to be able to add JUST ONLY the 4 angles simple rotations to an image WITHOUT using the rotate component that disable the seamless option
Use the ZOOM at 0 value
Also if you use the Rotate component with a simple slider you will not be able to rotate to an exact full rotated image angle unless you know exactly the amount of degrees, so this filter helps to build a fixed 4 angles fixed rotation simple without confusion.
The only possible problem is that for this to work is that you can ONLY use it with square images. But I think that maybe it could be fixed in some way, will see if it is possible to find a way
Thanks very much for making this
Thanks SpaceRay......
Yep this only works with square images...It was made with FF1 and non-square components were not introduced until later versions of FF....
I have not thought about re-building this filter since it was only for a certain function and purpose. You could try to use the non-square components
and re-make this filter.
22 unregistered users.
