David Roberson
Artist
Filters: 37
Nebula Lab II by David Roberson
http://www.filterforge.com/filters/15836.html
David Roberson
Artist
Filters: 37
Yay! This is already up!
Much gratitude for the Editor's Pick! That really made my day!
Erik Pedersen
Goggerfett
Absolutely beautiful output! Worth the wait and thanks so much for thoughtful considerations like being able to turn the stars on or off.
The Joy is in The Work
David Roberson
Artist
Filters: 37
Thanks, Erik! I'm glad those options are helpful.
A very fine tool to create diffuse nebulae. Congrats on the EP!
Did you intend for the scaling and offset to be turned off when the stars are off? I'd like to be able to scale the result with no stars.
David Roberson
Artist
Filters: 37
Thanks Rachel!
I had no idea it was doing that. I'll poke around a bit to see if I can find out why. It should be transformable even without stars. Probably a mixed up connection somewhere...
David Roberson
Artist
Filters: 37
Okay, it turns out the Offset and Scale were bypassed on the Switch connection for the starless background. I must have added those components after creating the switch, and just forgot to connect it. I'll try to remember to submit the update again later, since it would not accept it today due to some connection error. Until then, you can use the attached copy.
Nebula Lab II.ffxml
27 unregistered users.
