NightSkyDreamer
Stöcksjö Sjömyrväg 43
NightSkyDreamer
Hello,
I use Filter Forge 9, latest by today and you filter does not show colors, just grey flower...
Other filters are colored ..
I had a couple of another filters with similar problem, they were grey as well.
I have quite modern Windows PC (4 cores) 32GB memory with Nvidia card and two displays.. it is not with my HW ...
NightSkyDreamer
render result here...
GMM please remove the previous posts. This has been solved in another thread
UPDATE: The filter requires an external image, but was probably given a white new image. Also it appears that it was output without transparency, so the background appears in solid colors, so make sure transparency is turned on when you save the image. Also, read the About section of the filter, sometimes there is useful information, in the case of this filter, how to use it.
33,849 Registered Users
+12 new in 30 days!
+7 new in 7 days!
15,392 Topics
+44 new in year!
16 unregistered users.
