9-Slice Scaling External Image by ThreeDee
http://www.filterforge.com/filters/15758.html
Since it is not too obvious how this works:
Load an image into the input image, set the margins using the guides, then create a new image at the dimensions you want to convert the image to. The input image will be adjusted to the new image dimensions using the guides to keep the corners original size, stretching the edges in one dimension and the center area in two dimensions.
Turn the guides off for final render.
