Spago Tri by Ramlyn
http://www.filterforge.com/filters/15726.html
Great use of symmetry here. The triangular / hexagonal patterns are endless, I should know smile;-)
Here's A Clever Spider:
Fall Leaves
modified Flowers Stars Medallions
Spago Tri modified, enabled alpha in the background, great filter construction on examination
Clouds by GIMP
Filters: 712
Thanks Rachel Duim! smile:D
Your image is really beautiful.
It seems that our filters blended together can make very nice pictures. smile:D smile:D smile:D
Wow!! This is really awesome and amazing! It even has the pins correctly positioned as in real string art, and also has fractal combinations
Oh, yes!! you have been able to make so well the strings art idea, I tried myself but only could make one open triangle that looks close to it but not as good and great as you have done it, as my version have less strings, but yours is perfect and exactly how it should be
Congratulations on making it, I will see your filter and test it, thanks really very much for making it as I like it very much
This can be surely have more options and features added as it has plain colors and could be used in other different ways
quote]Rachel Duim wrote:
Here's A Clever Spider: [/quote]
Cool and well done combination of filters to make this beautiful example
Filters: 712
Thanks SpaceRay! smile:D smile:D smile:D
I'm working on a similar filter using different polygons.
Let's see if the result is nice enough.
Filters: 712
A small preview:
Oh, this is great and well done, like it much.
Here I have found this on internet something that makes this by hand that is really hard, and thanks to your filter we can do it very easy with the computer
Real Hand made string art composition
And is also shown this one with other colors
And this one
And also this other one that is also handmade too
String art flower of life
I still like much this idea and I think it could be expanded with some mandala compositions and with more colors
I will try myself some tests and see what I can get
I have just found this on Internet as inspiration example
Filters: 712
I tried to make some mandala using this filter as base, but finally the result didn't satisfy me, so I gave up.
Instead your last picture (by the way, very nice picture) made me think about using semi transparent surfaces......... I will test it. smile:D
The image of december 22th, 2020 is fabulous, I love it ! smile:) smile:) smile:)
Filters: 712
Thank you! It can be done easily, using Spago Evolution Rebirth R
These are the settings:
