Heptaflower by Rachel Duim
http://filterforge.com/filters/15452.html
I like very much all your flower filter and are unique and original, well done and these beautiful flowers can be used in other designs as I have already done here below
This above have been done with a modified version using the Fractal Bomber without shadow from ThreeDee and my modified version
And here is the filter that is able to make this thing, I have added some presets with and without the fractal, and have added some text to the about tab
I have selected this flower, but you can also choose to use any of the other flowers available that Rachel have already done as seen here Rachel Duim TriFlower, QuadFlower, Pentaflower, Hexaflower,Heptaflower
Heptaflower fractal bomber.ffxml
What a great job! Both you and RaGi on Facebook have taken my filters to another level. Thanks so much smile:-)
UPDATE: will be looking at your various mods and trying them out. I’ll post filter mods later...
Thanks, glad you like it and is interesting that you are trying other mods and will be waiting what you may be able to do
I have though that in the same way as above I have made the fractal Bomber, there is also the fractal hyperbolic tiling available in FF
and here is a zoom detail
And here is the filter that makes this
The above example is preset 1
I have made many different presets to see what can be done, there is 41 presets, mostly made from the presets you have already done
14 unregistered users.
