Koch Square by Rachel Duim
http://filterforge.com/filters/15553.html
This is interesting and cool how is done and is unique and different way to make this kind of tiling and great idea to combine fractals triangles to make a square pattern
Like it and it can have a potential to do also other things
After seeing how it works, I had an idea to continue furthermore the fractal way it works and make it multiplied by X2 and X3 and even be able to show the square not fully filled
I have put a new option with 9 values that are explained in the about tab of the filter
I have tested the speed and using the one you have created and the new X2 or X3 it seems that is about the same
It is totally up to you if you like to make a new version or update it, is just only a possible suggestio, and if like the idea, maybe you know another way to do it.
Koch Square Iteration Multiply.ffxml
24 unregistered users.
