Puzzling Curve by Rachel Duim
http://www.filterforge.com/filters/15532.html
This looks great and like much the idea of it and how it is overlays the source image, and how is made the fractal curve in such aMAZEing way
One persons puzzle is another persons maze smile;-) Thanks to Peano, Hilbert and Moore for figuring out these crazy things.
I know that it is not really a usual maze, but it looks like it from a distance, and I also wanted to use the word for showing how AMAZING and AWESOME this curves are done.
Is really excellent how you have been able to mix all these fractal curves into a single filter and do it well, great
Peano Curve Wikipedia
In geometry, the Peano curve is the first example of a space-filling curve to be discovered, by Giuseppe Peano in 1890.[1] Peano's curve is a surjective, continuous function from the unit interval onto the unit square, however it is not injective
Moore Curve
A Moore curve (after E. H. Moore) is a continuous fractal space-filling curve which is a variant of the Hilbert curve. Precisely, it is the loop version of the Hilbert curve, and it may be thought as the union of four copies of the Hilbert curves combined in such a way to make the endpoints coincide.
Because the Moore curve is plane-filling, its Hausdorff dimension is 2.
The following figure shows the initial stages of the Moore curve:
Hilbert Curve Wikipedia
A Hilbert curve (also known as a Hilbert space-filling curve) is a continuous fractal space-filling curve first described by the German mathematician David Hilbert in 1891,[1] as a variant of the space-filling Peano curves discovered by Giuseppe Peano in 1890.[2]
Because it is space-filling, its Hausdorff dimension is 2
sascha-kasper learning curve
A normal learning curve eventually leads to mastery. But the road is a bumpy one.
Your own learning curve is of course at the top as you are able to make such great, unique and original things.
Thanks for the details SpaceRay! I did not do Peano, that one was a different seed shape. As for learning curves, I'm so old the curve is flat... or worse. For me the bumpy road is on days the coffee is not working. I never feel I've completely mastered anything, there is always something more to learn. Some stuff is like muscle memory, you just have to do it enough. I knew little about space filling curves until I saw this: Brainfilling Curves. Very educational and fun.
26 unregistered users.
